95 EG - Is front LCA bolt welded too?
https://honda-tech.com/zerothread?id=1635141
https://honda-tech.com/zerothread?id=1328372
https://honda-tech.com/zerothread?id=439180
All posts about people who broke their rear LCA bolt. So if anyone knows whether the front LCA bolts are welded too, please post.
Nice. Thank you. I just got my H&R Race/ Koni Yellows setup, and I'm ready to put them in. I was gonna lower my car a year ago, but stopped because I broke the rear LCA bolt. So I fixed that with GSR LCAs and left my suspension alone.
just buy new...or "new" lcas when your gona replace your rear suspension...then just unbolt the shock from the body, then unbolt the lca from the subframe and the spindle....'tis what i did since the lower shock bolt didnt want to come off.
note the orange LCAs
Just soak the bolt with some sort of penetrating oil (liquid wrench), I've always used PB Blaster, and let it sit for a while before you try loosening the bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaman86 »</TD></TR><TR><TD CLASS="quote">Just soak the bolt with some sort of penetrating oil (liquid wrench), I've always used PB Blaster, and let it sit for a while before you try loosening the bolts.</TD></TR></TABLE>
the problem with me was that it was rusted into the metal sleeve, no amount of penetrating oil would have saved it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch »</TD></TR><TR><TD CLASS="quote">just buy new...or "new" lcas when your gona replace your rear suspension...then just unbolt the shock from the body, then unbolt the lca from the subframe and the spindle....'tis what i did since the lower shock bolt didnt want to come off.
I already fixed the rear suspension, I was just making sure that I wouldn't run into the same problem when I tried to do the front.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bigmojoj27 »</TD></TR><TR><TD CLASS="quote">
I already fixed the rear suspension, I was just making sure that I wouldn't run into the same problem when I tried to do the front.</TD></TR></TABLE>
no sir, it should be a breeze
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports »</TD></TR><TR><TD CLASS="quote">sleepy whered u get those lca's? </TD></TR></TABLE>
They look like Omnis.
Charlie Moua
Suspension & Brakes
11
Sep 8, 2014 04:18 AM
Charlie Moua
15
Sep 5, 2014 01:51 PM
BoostinEJ1
41
Apr 16, 2006 01:18 PM
