seized - bolt/bushing
Old Jan 5, 2004 | 02:17 PM
B18G's Avatar
Default seized - bolt/bushing
I posted a while ago about my stripped bolt head. Turns out the reason this happened was because the inner metal part of the bushing was seized to the bolt!
The bolt i'm talking about is on the rear compensator arm, the one that goes on to the chassis for rear wheel alignment.
So I realized this when I finally got the bolt loose (with a pipe wrench), and I didn't notice any distance between the chassis and the bolt head. instead I saw some exposed thread around the bushing, I was bending the chassis! So I pried the compensator arm off the bushing sleve a bit to expose it. Anyone have any idea of what to do now? I was thinking about torching it, I tried hammering the chassis plate in a bit with a chisel. No luck so far.
I'll try to get pics up soon so it'll give a better idea of what I'm talking about.
Old Jan 5, 2004 | 03:35 PM
Burke's Avatar
Banned
Default Re: seized - bolt/bushing (B18G)
same thing happened to me on the rear lca where the shock bolts on. i, uhhh, cut the shock off and went and used a press to get the bolt out. i hate that bolt
Old Jan 5, 2004 | 03:39 PM
Sliced Beard's Avatar
Default Re: seized - bolt/bushing (Burke)
word to the wise always grease contact points on a honda component
otherwies you will have this problem
i had the same thing happen to me a yesterday
i took pb blaster and a 2lb sledge and a ball joint (pickle fork) seperator to it
it eventually came apart and i had to bend the chassis back straight
lucily i was doing a rear disk conversion and i had a new one to replace it with
Old Jan 6, 2004 | 08:48 PM
B18G's Avatar
Default Re: seized - bolt/bushing (dirtyd463)
Thanks for the input guys.
I guess its the crazy age of the bolt and bushing, definatly will grease.
Finally got it out today ... i ended up torching it a couple of times, then taking a vice grip to the bushing sleve and the bolt. Some crazy twisting and the thing finally gave. Damn ... definatly dun wanna go thru that again ...
sde780
Oct 28, 2009 02:36 AM
OneDirection
Suspension & Brakes
13
Jan 17, 2005 07:19 AM
jweezy225
Nov 1, 2004 02:38 AM
logictron2000
15
Apr 24, 2003 08:59 AM
Matt B
Apr 20, 2003 07:12 PM
