Draining coolant out of block !?
Old Nov 8, 2006 | 07:52 AM
93(Civic)EG6's Avatar
Default Draining coolant out of block !?
Ok I have drained coolant out of block and radiator, now how do I get the coolant to be completely flushed out of the block? I searched and one guy said he just kept putting water into the block and turning his heat to max to flush the block. I have also heard of taking off the thermostat and flushing it with a garden hose but i dont want to take the thermostat off because i don't want to mess with anything that is fine and would rather work around it. The reason I am doing this is because I am changing brand of coolant so i would like it completely flushed. Any ideas?
Old Nov 8, 2006 | 08:25 AM
Default Re: Draining coolant out of block !? (93(Civic)EG6)
bump
Old Nov 8, 2006 | 08:28 AM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93(Civic)EG6 &raquo;</TD></TR><TR><TD CLASS="quote">Ok I have drained coolant out of block and radiator, now how do I get the coolant to be completely flushed out of the block? I searched and one guy said he just kept putting water into the block and turning his heat to max to flush the block. I have also heard of taking off the thermostat and flushing it with a garden hose but i dont want to take the thermostat off because i don't want to mess with anything that is fine and would rather work around it. The reason I am doing this is because I am changing brand of coolant so i would like it completely flushed. Any ideas? </TD></TR></TABLE>
taking the t-stat out would definately help things, unless your garden hose spews boiling water
Old Nov 8, 2006 | 08:48 AM
POE's Avatar
POE
yeah i say get a water house and start sprayin it down there.. and then get a wrag wrapped around a flat tip and dry up all the water
Mikey3000
Jun 23, 2008 04:31 AM
integraboosted
Oct 13, 2007 09:20 PM
I8ayellowcrayon
Sep 6, 2005 05:55 PM
XxslayerxX
27
Oct 19, 2003 11:33 AM
