Which tranny fluid to use??
1 Post
Steve at hmotors recommended Redline with an LSD additive but no shops around me carry it. Is there any other recommended brand that has an LSD additive that I can ask for?
Re: Which tranny fluid to use?? (CivicSwapper)
i use lucas oil for my lsd it works great. where i live you get almost 15 passes down the tract and it holds really well to extreme temps.
1 Post
Re: Which tranny fluid to use?? (f20b eg)
trying to find something local. So far the mechanic Im using (good friend) said that none of the shops around us carry redline products. Which is why im trying to find an alternative. After searching, Im seeing a lot of vouches for GM Synchromesh with Friction Modifier. Will this work if I can get my hands on it? Steve said the LSD is a Cusco if that has any bearing
I would first find out what type of LSD you have. Then I would ask said manufacture what they recommend using in your particular transmission with their LSD.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KAAZ USA »</TD></TR><TR><TD CLASS="quote">Oil for Kaaz LSD
It is important to use 80W/90 GL-5 specification gear oil on Kaaz LSD. We highly recommend using our own Kaaz LSD fluid.
DO NOT USE SYNTHETIC BASE OIL ON KAAZ LSD. Kaaz LSD may not function smoothly.</TD></TR></TABLE>
CivicSwapper
11-30-2006 02:16 PM
