will a d16 tranny from 92-95 fit on a 96-00 civic d16y8?
Old Nov 5, 2006 | 11:12 PM
89civicb16a1's Avatar
Default will a d16 tranny from 92-95 fit on a 96-00 civic d16y8?
will a d16 tranny from a 92-95 fit on a 96-00 civic d16y8? which one would be better the 92-95 or 96-00 the 92-95 is 100$$ cheaper
Old Nov 5, 2006 | 11:15 PM
allmotorabe's Avatar
Default Re: will a d16 tranny from 92-95 fit on a 96-00 civic d16y8? (89civicb16a1)
yes it will its all the same
themorphious's Avatar
doesnt the y8 tranny have longer gears?
Old Nov 5, 2006 | 11:22 PM
Steven.'s Avatar
Get ex or si trans the gears are shorter
Old Nov 5, 2006 | 11:24 PM
Default Re: (Steven.)
what the 92-95?????
Old Nov 5, 2006 | 11:45 PM
POE's Avatar
POE
u want a tranny thats from an ex/si and the d16y8's have the same gears, inthe ex. and a stocker shift for.. So look for those kinds yo.
Old Nov 6, 2006 | 12:28 PM
HondaEJ7's Avatar
yes any tranny from 92-00 will fit, as long as the motor is a d-series (d16, d15)
heres the main differences:
92-95
-P20/A000 is for DX/CX/VX
-P20/B000 is for EX/Si
Nonturbo, go for B000 for shorter gears
Turbo, go for A000 for longer gears and better traction.
-ALUMINUM SHIFT FORKS
96-00
-D16y8 (EX) has shortest gears
-No SI tranny because SI 99-00 is a b-series
-D16y7(DX,CX,LX), D16y5(HX) have longer gears
-STEEL SHIFT FORKS
If it was me, I would go with a d16y8 tranny, shortest gears and steel shift forks. unless you turbo.
for more detailed info:
http://home.cinci.rr.com/mistab0ne/tranny.
Modified by HondaEJ7 at 10:11 AM 11/7/2006
Old Nov 6, 2006 | 07:12 PM
unsungsohc's Avatar
Default Re: (HondaEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">I would go with a d16y8 tranny, shortest gears and steel shift forks. unless you turbo.</TD></TR></TABLE>
i agree with ^. i have the d16z6 tranny on my y8 and have had nothing but problems with 3-4 shift fork breaking.
Old Nov 6, 2006 | 08:10 PM
dem0nk1d's Avatar
I have a question on the older 92-95 tranny's, the tranny codes where just a sticker. So how can you tell other wise what the tranny is if the sticker doesn't exist. Second question is that the 96+ newer, I heard have metal vin tags rivited to the tranny. Is this true?
Old Nov 6, 2006 | 10:54 PM
sohc_coupe24's Avatar
There should be a penny size stamp near the axle hole to verify which tranny you have.
Old Nov 7, 2006 | 07:10 AM
HondaEJ7's Avatar
yea it wasnt that metal plate that you are thinking. there should be an ingraved number in the casing of the transmission that shows what kinda it is. should be by the VSS
Old Nov 7, 2006 | 08:58 AM
Bense's Avatar
d16z6 and d16y8's have the same gears.
y8 2nd is 0.47% shorter than z6 second.
del sol si and hatchback si d16z6 models use a 0.750 5th instead of 0.702 5th
alum forks break
steel forks bend
I prefer aluminum z6 forks, Mista Bone prefers z6 forks. There's a reason behind this.
all sensors are the same.
Old Dec 19, 2010 | 09:35 PM
killa94's Avatar
what tranny code is the y8???
fryman
Dec 20, 2008 11:11 AM
95civhb
Jul 5, 2006 03:10 PM
Old School CRX Swap
May 23, 2006 09:53 AM
ieatrice
10
Feb 15, 2006 11:13 AM
GdmLaz
26
Nov 15, 2005 02:23 PM
