BLOWING FUSES LEFT TO RIGHT
Old Oct 30, 2006 | 10:46 PM
SkIp_Civic_Ek6's Avatar
Default BLOWING FUSES LEFT TO RIGHT
the fuse to the alternator and sp sensor (speed sensor) keep blowing i keep putting in a new fuse yet iono wah the problem is i pull the battery wen the car is started the positive to see if the alternator is bad i guess not well iono if thats a good way to check heard it from a friend then i checked everything still dunno wah the problem is and then before i put a new fuse in i took the speed sensor clip off and put the new fuse in and again it blows the fuse......can anybody help me?
Old Oct 30, 2006 | 11:04 PM
fmrprojects's Avatar
Default Re: BLOWING FUSES LEFT TO RIGHT (SkIp_Civic_Ek6)
tou have a short somewhere. check and see if wire is touching any metal
Old Oct 30, 2006 | 11:57 PM
Jhonny Ricer's Avatar
Default Re: BLOWING FUSES LEFT TO RIGHT (fmrprojects)
Id say check to see if wires are touching metal and also check your ground could be loose or bad connection causing your short to have nowhere to run out too and just stay in your line
Old Oct 31, 2006 | 06:32 AM
lightcrx's Avatar
check the wires on the back(under) of the manifold
the harness rubs on the bracket and causes it to short out
Old Oct 31, 2006 | 08:53 PM
phyzJunkieCivic's Avatar
From: Dont You Just Love Lynn Cops, Boston MA, USMA
Eddie alopp your so stupid, ask slick what he had did to your harness. He might tell you hahahha
RVMIRXZem1
Oct 26, 2018 07:05 PM
w0ng_sta
Nov 8, 2006 05:29 PM
premier_ek9
Nov 2, 2006 09:48 AM
x justin
Aug 15, 2006 09:38 AM
CA6VTEC
Aug 2, 2006 05:31 PM
