Alternator/Sp sensor Fuse keeps blowing
I’ve check grounds , Wiring , New battery, New alternator, Good speed sensor. Ill replace the Fuse and take it around the block after like 2 pulls once it gets higher in the rpms The Fuse blows and my speedometer stops working. I have not check the grounds with a multimeter yet
Re: Alternator/Sp sensor Fuse keeps blowing
If it's a 1996-2000 model, there is one particular spot on the harness that gets worn through and shorts out. Search for the "fuse 15 problem."
Definitely check for shorted wires under the intake manifold bracket. If that's not the problem, then check for a shorted O2 sensor heater wire. They are another common cause for fuse 15 blowing.
RedneckRicer
20
04-09-2014 08:19 PM
SkIp_Civic_Ek6
10-31-2006 08:53 PM
