high rpm code 43 and 22
Old Oct 29, 2006 | 01:11 PM
blk92hatchsi's Avatar
Default high rpm code 43 and 22
i have a 92 civic hatchback si with the stock z6. it has intake, mild headwork, header, and exhaust. when i get around 6 grand or higher in second gear and shift into third fast the CEL comes on. i checked the codes and it was 43(fuel supply system) and 22(oil pressure switch). when i turn the key off and back on it gos away.
when i bought the car a week ago the kid told me in need a vtec silenoid and i had one laying around that i knew worked so i put it on and didnt make any diffrence.
i was reading about code 43 and put a fuel pressure gauge on to check the fpr becouse it was easyist to check and it was fine.
the car dosnt run bad i just dont know why it would throw code 43 and 22 at the same time and both go away when i shut off the car. should i try taking the neg off the battery sence i changed the whole silenoid and pressure switch and if so whould it have anything to do with the fuel supply system cel at all?
ennohohbee
Dec 23, 2013 02:05 PM
saintbhts
Jun 12, 2013 09:43 PM
Thizzed Out
Mar 29, 2009 05:09 AM
blk92hatchsi
Nov 14, 2006 09:58 PM
97AccordCD5
Dec 13, 2004 01:22 PM
