Test Pipe w/ o2 censor
Will the O2 censor be effected in any way if i put on a test pipe instead of a catalytic converter? I hear the check engine light might turn on. Does it mess with the computer in any way? I have a 2001 gsr
test pipe with a hole to put in o2 censor will be no prob..
you could always get a O2 sensor simulator or get a high flow cat like car sound(what i got) or random tech then you can install your O2 sensor like normal without any problems.
[Modified by strils, 3:43 AM 5/6/2002]
You could not do anything with the o2 sensor and just let it get atmospheric air and wrap it in foil so it can't get wet, and ziptie it to something so it can't move around.
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
