Test Pipe w/ o2 censor
Old May 5, 2002 | 06:50 PM
s2k's Avatar
s2k
Default Test Pipe w/ o2 censor
Will the O2 censor be effected in any way if i put on a test pipe instead of a catalytic converter? I hear the check engine light might turn on. Does it mess with the computer in any way? I have a 2001 gsr
Old May 5, 2002 | 07:21 PM
comptechgsr2000
Guest
Posts: n/a
Default Re: Test Pipe w/ o2 censor (CivicKilla)
Yes your CEL light will come on. However your performance will be fine.
Old May 5, 2002 | 07:25 PM
s2k's Avatar
s2k
Default Re: Test Pipe w/ o2 censor (comptechgsr2000)
Can I turn off the light with the button under the steering wheel consol?
Old May 5, 2002 | 07:43 PM
comptechgsr2000
Guest
Posts: n/a
No thats for service, i.e 15000 tune up
Old May 5, 2002 | 08:36 PM
94tegAddict's Avatar
test pipe with a hole to put in o2 censor will be no prob..
Old May 5, 2002 | 09:47 PM
JeffS's Avatar
Default Re: Test Pipe w/ o2 censor (94tegAddict)
That's not true in his case. On your '94, it's correct, but he has a 2001 with 2 oxygen sensors. On an ODBII car, the downstream sensor will throw a code on a test pipe. One option I've heard of is to insert some catalyst into the O2 bung then insert the downstream sensor. *Supposedly*, this will prevent a code.
Old May 5, 2002 | 11:36 PM
Duck Sauce's Avatar
Default Re: Test Pipe w/ o2 censor (JeffS)
The car will not go into "safe mode" if you put on a test pipe. Code 67 means catalytic converter failure, the CEL won't affect anything, just ignore it.
Old May 5, 2002 | 11:42 PM
strils's Avatar
Default Re: Test Pipe w/ o2 censor (DC2ownz)
you could always get a O2 sensor simulator or get a high flow cat like car sound(what i got) or random tech then you can install your O2 sensor like normal without any problems.
[Modified by strils, 3:43 AM 5/6/2002]
Old May 5, 2002 | 11:59 PM
dubster99's Avatar
Default Re: Test Pipe w/ o2 censor (strils)
You could not do anything with the o2 sensor and just let it get atmospheric air and wrap it in foil so it can't get wet, and ziptie it to something so it can't move around.
mxracer420
Mar 25, 2010 04:33 PM
kevinm1981
Oct 7, 2009 02:58 PM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
TURBOED-TEG
Jun 24, 2002 09:19 AM
amrintegra
Nov 5, 2001 07:21 AM
