02 sensor
Old Sep 18, 2009 | 01:10 AM
kevinm1981's Avatar
Default 02 sensor
I have a 98 Integra GS with usdm header and skunk2 test pipe and have two o2 extenders, should I use them both or just put one at the test pipe?
My check engine light comes on and I am pretty sure its cause of the o2 sensor on the test pipe.
Old Sep 18, 2009 | 04:09 PM
kevinm1981's Avatar
Default Re: 02 sensor
ttt
Old Sep 18, 2009 | 07:14 PM
variable's Avatar
If I am understanding you right...you are asking if you should use a cel eliminator on the o2 in the header and the test pipe or just the test pipe...
Just use one on the o2 going into the test pipe
Old Sep 18, 2009 | 07:16 PM
variable's Avatar
...and dont forget to reset your ECU properly
Old Sep 18, 2009 | 07:35 PM
kevinm1981's Avatar
Ok, I was thinking i only needed one on the test pipe.
Old Oct 7, 2009 | 02:24 PM
kevinm1981's Avatar
Ok, the o2 extender doesnt fit due to clearance.
Old Oct 7, 2009 | 02:33 PM
follie gatts's Avatar
you can check your code using the link in my signature CEL Trouble Codes
your 98 is OBD2 if stock and requires two oxygen sensors
Old Oct 7, 2009 | 02:58 PM
kevinm1981's Avatar
The o2 won't go back in either due to the threads being stripped.
I guess I am going to get a catalytic converter on there and two new o2 sensors.
mxracer420
Mar 25, 2010 04:33 PM
avotegra
Nov 25, 2008 04:23 PM
Dai_Ca_Vietnam_H22a4
May 21, 2005 08:42 PM
Chris_Bye
May 1, 2005 07:56 AM
TURBOED-TEG
Jun 24, 2002 09:19 AM
