headgasket ?
Old Oct 24, 2006 | 05:23 PM
mtownsi's Avatar
Default headgasket ?
hey wats good i got a 99 si b16a2. i bought a b17 wit pct pistons so ima take the internals out of the 1.7 and put them in my b16 but i did the comp calculator and it said i was gonna be at like 12.4-1 cr so can i use a oem headgasket or should i go wit a cometic or aftermarket
Old Oct 24, 2006 | 06:03 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: headgasket ? (mtownsi)
Well unless you plan on buying 100 octane, I would just put on an OEM one
Old Oct 24, 2006 | 07:31 PM
mtownsi's Avatar
well i know cometic sells headgaskets to lower ur cr alil so i wasnt sure if that would be a good idea or just leave it oem and also a b16a2 timing belt kit is correct to be using right iight thanks
Old Oct 25, 2006 | 04:20 PM
mtownsi's Avatar
bump bump
Old Oct 25, 2006 | 04:24 PM
chrisw85's Avatar
thats going to be a pretty high compression on pump gas. I hope your going to thoroughly tune it. I'd use a stock 3 layer gasket unless you want to bump the compression up even more.
Old Oct 25, 2006 | 07:20 PM
mtownsi's Avatar
Default Re: (chrisw85)
i need to purchase thet-belt kit and headgasket asap so anymore input would be good
Old Oct 26, 2006 | 03:08 PM
mtownsi's Avatar
Default Re: (mtownsi)
bump
Old Oct 27, 2006 | 10:14 AM
mtownsi's Avatar
any1 have any opinons or anything
hybrid1990crx
10
Feb 11, 2007 04:40 PM
vtecRDS
Nov 26, 2005 09:43 PM
raider099
Mar 3, 2005 04:07 PM
slowsleeper
Sep 15, 2004 08:04 PM
infra
Aug 6, 2004 11:43 AM
