2 oem headgaskets or get a aftermarket one?
im putting together my stock internal motor and im curious if i should get 2 oem gaskets or just buy a aftermarket one. i want something to lower my compression. it will be jdmb16a head with 95 b18 block. turbo. thank you
Re: 2 oem headgaskets or get a aftermarket one? (SOHC_MShue)
u can get a thicker headgasket at http://www.inlinepro.com give them a call and see what they recomend they have stock motors with headgaskets making well over 300hp
Re: 2 oem headgaskets or get a aftermarket one? (Mpir3)
Stock headgaskets retail for what $80 from Honda. X2=160
Cometic .43 gasket will lower the compression and is like $100 shipped.
BTWm you really dont need to lower the compression
It would probably be cheaper to buy a low compression HG compared to 2 OEM HG. But if you want to run two I suggest a product called indian headgasket treatment. You can get it @ NAPA. Just put it between the 2 gaskets. And remember when you use a thicker gasket it throws your timing off so adjustable cam gears will be needed.
Re: (EG1.8cT68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1.8cT68 »</TD></TR><TR><TD CLASS="quote">And remember when you use a thicker gasket it throws your timing off so adjustable cam gears will be needed.</TD></TR></TABLE>
young noob
07-05-2007 11:51 AM
Sassafrass
09-16-2003 01:15 PM
Black DC2
06-09-2003 06:31 PM
