headgasket ?
headgasket ?
hey wats good i got a 99 si b16a2. i bought a b17 wit pct pistons so ima take the internals out of the 1.7 and put them in my b16 but i did the comp calculator and it said i was gonna be at like 12.4-1 cr so can i use a oem headgasket or should i go wit a cometic or aftermarket
Re: headgasket ? (mtownsi)
well i know cometic sells headgaskets to lower ur cr alil so i wasnt sure if that would be a good idea or just leave it oem and also a b16a2 timing belt kit is correct to be using right iight thanks
thats going to be a pretty high compression on pump gas. I hope your going to thoroughly tune it. I'd use a stock 3 layer gasket unless you want to bump the compression up even more.
hybrid1990crx
10
02-11-2007 04:40 PM
slowsleeper
09-15-2004 08:04 PM
