air intake question
Old Oct 23, 2006 | 11:32 PM
ic89's Avatar
Default air intake question
i am planning to get an aem cold air intake for my 92 eg 4dr. i am not sure if i should buy it because i have heard stories thaT water can go in the intake and then flow into the engine and harm it. is this common???
Old Oct 23, 2006 | 11:34 PM
BlueIntegraBoy's Avatar
Default Re: air intake question (ic89)
Unless you plan to run over some puddles, you don't have to worry too much. The filter is still pretty high off the ground and it's enclosed by your bumper and fender liner. AEM makes an air bypass valve that you can use in conjunction with your AEM CAI.
Old Oct 23, 2006 | 11:58 PM
ic89's Avatar
Default Re: air intake question (BlueIntegraBoy)
yea i was thinking about buying a bypass valve as well however i was told it can break easily is this true?
Old Oct 24, 2006 | 12:01 AM
ic89's Avatar
also will the bypass valve decrease performance of the intake system ??
Old Oct 24, 2006 | 12:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ic89 &raquo;</TD></TR><TR><TD CLASS="quote">also will the bypass valve decrease performance of the intake system ??</TD></TR></TABLE>
It might, since it also sucks up air from the engine bay. I don't know how it could break. It's a piece of foam with couplings at the ends.
Old Oct 24, 2006 | 12:04 AM
ic89's Avatar
i have a front kit and its a pretty open area so water could get in their how high would u say the filter is
Old Oct 24, 2006 | 12:07 AM
I wouldn't know personally. I'd estimate around a foot.
Old Oct 24, 2006 | 12:11 AM
ic89's Avatar
ok uve been very helpful thanks a lot
m0squ1t0
Sep 10, 2009 08:10 AM
xxintegrlxx
Jun 22, 2005 03:38 PM
Fidelio25
Jul 7, 2004 03:54 PM
joserodriguez
Apr 8, 2003 12:20 PM
civic7gen
Jul 24, 2002 05:29 AM
