specs on Orthia
specs on Orthia
hi every one donno where too post but im after some specs on a honda orthia 96 Jdm only lol
it look like this ... im planing on getting one cus in NZ there the only manual wagons i can get with out a convo
Re: specs on Orthia (db8SI)
Google is your friend
<U>Model:</U> GX
Body type: Wagon
Drive: FF
Transmission: 5 speed manual
Displacement, cc: 1834
Frame: E-EL1
Price of new car, thousands yen (Tokyo area): 1668 (~$13900)
Exterior dimensions (LxWxH), mm: 4570 x 1695 x 1485
Interior dimensions (LxWxH), mm: 1765 x 1405 x 1150
Wheel base, mm: 2620
Treads (F/R), mm: 1475 / 1475
Ground clearance, mm: 160
Curb vehicle weight, kg: 1180
Seating capacity, persons: 5
Doors number: 5
Min.turning radius, m: 5.4
Fuel tank capacity, l: 52
Engine model: B18B
Max.power (Net), kw(PS)/rpm: 140 ps (102.97 kw) / 6300 rpm
Max.torque(Net), N*m(kg*m)/rpm: 17.4 kg*m (170.64 N*m) / 5200 rpm
Power density: 8.43
Engine type: Water cooling serial 4 cylinder DOHC16 valve
Engine information: Horizontal ranging belt driving
Fuel system: Electronic fuel injection system (HONDA PGM-FI)
Turbocharger: No
Fuel type: Unleaded regular gasoline
LEV system (Low emission vehicle): No
Compression ratio: 9.2
Bore, mm: 81
Stroke, mm: 89
Fuel consumption at 10-15 modes, l/100km: 7
Fuel consumption at 60 km/h, l/100km: 4.9
Power steering: Yes
Tires size, front: 185/65r14 86s
Tires size rear: 185/65r14 86s
Braking system, front: Ventilated disk
Braking system, rear: Drum (leading/trailing)
Suspension system, front: Double wishbone type
Suspension system, rear: Double wishbone type
Sunroof / Moonroof: n/a
Front fog lamp: no
Rear fog lamp: no
Xenon headlight (Discharge lamp): no
Projector headlight: no
Rear wiper: yes
Front spoiler: no
Rear or roof spoiler: yes
ABS (Antilock brake system): yes
TCS (Traction control system): no
LSD (Limited slip differential): no
Privacy glass: no
UV cutting glass: yes
Aluminium wheel: n/a
Air conditioner: Full automatic
Wood panel: no
Cruise control: no
Centralized door lock: yes
Power window: yes
Steering wheel telescopic: no
Steering wheel tilt: yes
Leather steering wheel: no
Power front seat: no
Power rear seat: no
Leather seat: no
Falling down type rear seat: Divided type
Child seat fixed with seat belt: no
Rear ELR3 point seat belt : yes
Front seat pretensioner seat belt: no
Fourth limited front seat belt: no
Side impact bar: yes
Airbag (Driver): yes
Airbag (Passenger): yes
Airbag (Side): no
Audio deck: AM/FM radio equipped cassette player
CD-player: no
Car navigation system: n/a
<U>Model:</U> 2.0 GX
Body type: Wagon
Drive: FF
Transmission: 7 position electronic control 4 speed automatic
Displacement, cc: 1972
Frame: E-EL2
Price of new car, thousands yen (Tokyo area): 1855 (~$15400)
Curb vehicle weight, kg: 1210
Doors number: 5
Engine model: B20B
Max.power (Net), kw(PS)/rpm: 145 ps (106.65 kw) / 6200 rpm
Max.torque(Net), N*m(kg*m)/rpm: 18.2 kg*m (178.48 N*m) / 5200 rpm
Power density: 8.34
Turbocharger: No
Bore, mm: 84
Stroke, mm: 89
Fuel consumption at 10-15 modes, l/100km: 8
Power steering: Yes
Front fog lamp: yes
Rear fog lamp: no
Rear wiper: yes
Front spoiler: no
Privacy glass: n/a
Wood panel: no
Cruise control: no
Power window: yes
Power rear seat: no
Leather seat: no
Airbag (Side): no
CD-player: no
<U>Model:</U> 2.0 GX-S
Body type: Wagon
Drive: FULL 4WD
Frame: E-EL3
Price of new car, thousands yen (Tokyo area): 2183 (~$18100)
Exterior dimensions (LxWxH), mm: 4635 x 1695 x 1500
Treads (F/R), mm: 1475 / 1455
Curb vehicle weight, kg: 1280
Doors number: 5
Fuel tank capacity, l: 53
Engine model: B20B
Power density: 8.83
Turbocharger: No
Bore, mm: 84
Stroke, mm: 89
Fuel consumption at 10-15 modes, l/100km: 8.9
Power steering: Yes
Tires size, front: 195/60R14 86h
Tires size rear: 195/60R14 86h
Front fog lamp: yes
Rear fog lamp: no
Rear wiper: yes
Front spoiler: no
Privacy glass: yes
Wood panel: yes
Cruise control: no
Power window: yes
Leather steering wheel: yes
Power rear seat: no
Leather seat: no
Airbag (Side): no
CD-player: no
Modified by BlueIntegraBoy at 12:35 AM 10/24/2006
<U>Model:</U> GX
Body type: Wagon
Drive: FF
Frame: E-EL1
Doors number: 5
Engine model: B18B
Power density: 8.43
Turbocharger: No
Bore, mm: 81
Stroke, mm: 89
Power steering: Yes
Front fog lamp: no
Rear fog lamp: no
Rear wiper: yes
Front spoiler: no
Privacy glass: no
Wood panel: no
Cruise control: no
Power window: yes
Power rear seat: no
Leather seat: no
Airbag (Side): no
CD-player: no
Body type: Wagon
Drive: FF
Frame: E-EL2
Doors number: 5
Engine model: B20B
Power density: 8.34
Turbocharger: No
Bore, mm: 84
Stroke, mm: 89
Power steering: Yes
Front fog lamp: yes
Rear fog lamp: no
Rear wiper: yes
Front spoiler: no
Privacy glass: n/a
Wood panel: no
Cruise control: no
Power window: yes
Power rear seat: no
Leather seat: no
Airbag (Side): no
CD-player: no
Body type: Wagon
Drive: FULL 4WD
Frame: E-EL3
Doors number: 5
Engine model: B20B
Power density: 8.83
Turbocharger: No
Bore, mm: 84
Stroke, mm: 89
Power steering: Yes
Front fog lamp: yes
Rear fog lamp: no
Rear wiper: yes
Front spoiler: no
Privacy glass: yes
Wood panel: yes
Cruise control: no
Power window: yes
Power rear seat: no
Leather seat: no
Airbag (Side): no
CD-player: no
2002, b20b, consumption, electronic, engine, fuel, honda, jdm, lev, orthia, orthias, spec, tech, transmission, tune
