RUNNING LEAN? bogging/hesitation from 2500-3k under light load...running lean?
Old Oct 20, 2006 | 07:39 PM
99blackdc2's Avatar
Default RUNNING LEAN? bogging/hesitation from 2500-3k under light load...running lean?
car boggs/hesitates at like 25% throttle (99 gsr) when hot...the first couple of minutes of driving there was nothing but i took it for a spirited drive and wen i was cruising again at 2500 it bogged and i gave it more gas and bucked and took off like it should....it has new plugs, wires, cap, rotor, fuel filter, fresh valvelash job. i pulled the plugs to lash it and the plugs where a whiteish/gray but not blistered like the haynes manual says. just the electrode is white/gray. im concerned about my fuel pressure. according to my cheapie pressure gauge is reading 32-35ish psi at idle when i think it should be like 38 to like 40 sumthing? im absolutely **** out of ideas...sumeone said O2 sensor but i thought that would throw a code and cause the car to run open loop which is on the rich side....ANY HELP IS GREATY APPRECIATED
Modified by 99blackdc2 at 2:00 AM 10/21/2006
Old Oct 20, 2006 | 08:20 PM
hondapvb's Avatar
Default Re: RUNNING LEAN? bogging/hesitation from 2500-3k under light load...running lean? (99blackdc2)
It sounds like you have a fuel psi problem. Your fuel psi needs to be 47-54psi. try pinching the fuel return line off to see if your pressure goes up. You may just have a bad regulator. Also watch you fuel gauge after shutting key off. Fuel psi shouldn't drop more than 10psi in 30 minutes.
Old Oct 20, 2006 | 10:56 PM
99blackdc2's Avatar
Default Re: RUNNING LEAN? bogging/hesitation from 2500-3k under light load...running lean? (hondapvb)
fuel psi goes down atleast 6psi after i shut it off
Old Oct 21, 2006 | 08:49 AM
JRTegman987's Avatar
anyone?
Old Oct 21, 2006 | 12:52 PM
99blackdc2's Avatar
bump
Old Oct 21, 2006 | 08:38 PM
99blackdc2's Avatar
Default Re: (99blackdc2)
bump; is there any reason u guyz think i shouldnt put my walbro 255 and aem fuel pressure reg turned down to stock pressure and see if the 2500rpm bogg stopps?
Old Oct 22, 2006 | 02:53 PM
99blackdc2's Avatar
up
Old Oct 22, 2006 | 04:11 PM
civicpower94's Avatar
i got the similar problem after warming up and starting to drive it runs fine after like 20-30 min if i start boosting again it hesitates especially if i give it more gas what can it be thanks
Old Oct 22, 2006 | 05:32 PM
99blackdc2's Avatar
Default Re: RUNNING LEAN? bogging/hesitation from 2500-3k under light load...running lean? (civicpower94)
your boosting tho...mines bone stock...i would think ur car is doing that for other reasons.
Old Oct 22, 2006 | 07:26 PM
99blackdc2's Avatar
bump
Old Oct 23, 2006 | 05:13 AM
99blackdc2's Avatar
replacing fuel pressure reg this week with stocker...anyone think i should leave my walbro 255 out and see if the stock pump is still good?
DawgC2
Mar 10, 2012 12:11 PM
YoungKadafi
Apr 1, 2007 04:43 PM
cincispeedemon
Aug 6, 2005 08:56 AM
hybridEj6
Nov 30, 2003 09:50 PM
tea
Sep 26, 2003 07:09 PM
