01 civic headlight problem
hello guys..
my 01 civic's right headlight low beams are not working. left is okay
and both headlight high beams work...
any idea what might be the problem? if the bulb is failed how can I change it?
tried to take it out but couldn't...
thx in advance.
thx in advance.
i had the same problem where my regular headlights went out and everything else was good (high beams, turn signals etc.) check your fuses in the fuse box under the hood top left corner. the fuse box cover has a mini diagram on which fuse goes to which light check to make sure the fuse isnt blown if not then go with the take the headlight out option and switch the bulb. (i learned this the hard way buying expensive *** aftermarket headlights when all that was wrong were the fuses lol)
ok i have the same problem the bulbs are good ive taken them both out and checked them fuses are also good everything works except for the low beams, brights turn signals and parking lights all come on anything else to check before i call honda tomorrow?
Modified by 01D17a1 at 5:23 PM 12/24/2007
so i just got done swaping out the bulbs and that seems to have solvedthe problem
stupid sylvania silverstars! im never spending 40 bucks on those headlights again!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01D17a1 »</TD></TR><TR><TD CLASS="quote">
Yea, I had those and they would never last more than a year. I started using the cheaper Sylvania Cool Blue blubs and they last far longer.
lkelly
Oct 17, 2008 04:29 PM
