b16 crank in ls block??????
Old Oct 17, 2006 | 07:11 PM
myblackhatch's Avatar
Default b16 crank in ls block??????
hey everyone. I was woundering if anyone could name any benefits of putting a b16 crank in an ls block. i archived this but didnt find anything of much use. im intending to run turbo on my ls and my idea was that sence the b16 crank (from what i understand) is more round then the b18 that i would allow the bottom end to handle more rev's My idea behind this is that, i would run b16 crank on b18 block with b16 head under boost. Run a big enough turbo so i dont start to spool until higher in the power band to give me a better chance of gaining traction. would it be better to edge the ls crank? anyone help me out with some good technical info??
Old Oct 18, 2006 | 07:22 AM
rmcdaniels's Avatar
Default Re: b16 crank in ls block?????? (myblackhatch)
Your rods would be too short. Why not just get a B16 bottom end? They are dirt cheap and you can boost/rev the hell out of them.
Old Oct 18, 2006 | 07:38 AM
so lazy's Avatar
just stick to the ls crank.. saves you some time.. i rev'd the **** outta my ls/vtec when i had it... new oil pump surely will help..
s.cha
Jan 3, 2017 03:12 PM
ILuvMyJdmDc4
Oct 21, 2008 04:30 AM
WickedHonda00
Mar 8, 2007 12:22 PM
eddiecut
Feb 2, 2003 10:35 AM
