b16a crank in a b18b block?
Old Nov 17, 2009 | 02:13 PM
s.cha's Avatar
Default b16a crank in a b18b block?
i am wondering is it good to put a b16 crank into a b18 block. cause i am planning on getting an ls block but its missing the crank. so i am just using the b16 crank but evrything else will be from the ls(pistons, rods, etc.)...well let me know what you guys think
Old Nov 17, 2009 | 02:41 PM
boostedEF91's Avatar
Default Re: b16a crank in a b18b block?
yes it will work.. b16 crank has a much smaller stroke than a ls.. i'd get a ls crank. you'll have a big loss in power. b16 stroke is 77 and a ls is 89mm. comparing also that the rods of a b16 are 134 and ls are 137.
Old Nov 17, 2009 | 02:44 PM
s.cha's Avatar
will it be good for turbo
Old Nov 17, 2009 | 02:49 PM
will be down on compression but will work.
Old Nov 17, 2009 | 03:37 PM
s.cha's Avatar
okay i have another question.
what if i transfer the b16 internals into a b18b bare block will everything just fit rite in? the reason i am asking is because my b16 block has 2 broken headstuds and they are stuck in the block and i know i'll have to tap in the vtec if i put a vtec head on if i do transfer everything to the ls block. lmk thanks
Old Jan 3, 2017 | 03:12 PM
Joven Greenaway's Avatar
S.Cha I'm sure you tried it...oh well that's what I did also I have a b16 crank in my b18c4 with high compression pistons and my car is working great
CircuitFG
May 4, 2005 01:19 AM
b16vtecsol
Jan 17, 2004 07:23 PM
eddiecut
Feb 2, 2003 10:35 AM
g2teg
Apr 8, 2002 03:38 PM
