mixing b16 w/ ls crank?
Old Feb 2, 2003 | 10:32 AM
eddiecut's Avatar
Default mixing b16 w/ ls crank?
u would use the ls rods and then would the compression go way up?? and anybody know what the rod stroke would be? and would u have to move the pins in the pistons up to make it work better?
Old Feb 2, 2003 | 10:35 AM
spettinger's Avatar
Default Re: mixing b16 w/ ls crank? (eddiecut)
have never seen a B18 crank in a B16 block. it would seem that an ls crank with an 89mm stroke would have some issues clearing a block meant to hold a 77mm crank. i think the journals might hit the block. not good. it would seem that you would need some serious notching at the bottom of the cylinder walls, this is never a good thing. now a B16 crank in an ls, on the other hand, should be able to rev high like a monster.
ILuvMyJdmDc4
Oct 21, 2008 04:30 AM
UNKNOWN_MEMBER
Apr 18, 2005 08:14 AM
JDMlyfestyle
Sep 27, 2004 02:06 AM
b18b-HB
Sep 2, 2002 06:08 PM
