srp 8:5:1 compression pistons fine with my setup?
Im almost finish with my build. I found a set of NEW in the box srp 8:5:1 pistons for my ls block for 200. Im gonna be running a t3/t4 57 trim turbo on an mildly built ls/vtec setup. I plan on running 16-18lbs tuned. Will these pistons be fine or should i spend retail value and buy higher compression pistons.
My setup.
Gsr head
AEBS intake manifold
AEBS 65mm throttle body
ARP Headstuds
Shaved??? im not sure how much i should yet.
Possibly port and plolished
Ls block
Oem golden eagle ls/ vtec headgasket
Stock bore SRP 8:5:1 pistons
Eagle h-beam rods with ARP rod bolts
ACL thrust washers, main bearings and rod bearings
Micropolished crank
Possibly a golden eagle block guard if it's worth it.
How much power would i possibly be looking at with this setup. And would it be fine? id like to break 350whp.
My setup.
Gsr head
ARP Headstuds
Ls block
Micropolished crank
MaxBoost
20
Jul 7, 2003 11:50 PM
