Need Opinions on new setup----stock internal GSR
Old Oct 16, 2006 | 09:47 AM
Schister66's Avatar
Man U FTW
Default Need Opinions on new setup----stock internal GSR
Right now i have a 275whp stock internal GSR. I want to see how far i can push this before i have to build. That being said, this is my ONLY car for the moment, but i will be getting another one. I still need my GSR to be reliable enough to daily drive. I have a few questions and need a few opinions on my next setup....
My setup so far:
Topmount mani, 3" dp, and dump
2.5" charge piping
Tial BOV and Tial 38mm WG
RC550 injectors
Tuned on Crome on 91-92octane
Precision 350hp IC (thinking about getting the 600hp but worried about excessive pressure drop)
My Questions:
1. What turbo should i use on my setup?? I have been tossing around the idea of a Precision SC6169 .63ar with the ported S compressor housing. I'm still undecided and would like to hear some other ideas. Hopefully looking to spend less than $850 on the new turbo.
2. What kind of power can i safely make on this setup?? I was thinking of getting tuned for around 350-360whp and running around 310whp daily. I dont want to needlessly stress anything because i need this setup to last at least most of next season. After that, i'm doing internal work. With the SC61, i was thinking of tuning on 14-16psi and then running 12 or so daily.
Thanks for all the help everyone!!
Old Oct 16, 2006 | 02:34 PM
Schister66's Avatar
Man U FTW
also, do you think i should look into a set of PTE880 injectors?? I dont know how far 550's will get me...360whp??
Old Oct 16, 2006 | 03:25 PM
TheShodan's Avatar
Moderator
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">also, do you think i should look into a set of PTE880 injectors?? I dont know how far 550's will get me...360whp??</TD></TR></TABLE>
550cc will get you up to about 395whp, and then that is about it.
As for your turbo selection, before going for a larger application for a stock motor, check out options to find out what turbo finds a bit best for your needs, not just peak output.
Old Oct 16, 2006 | 03:31 PM
Schister66's Avatar
Man U FTW
What would you recomend provided that i'm planing to build the engine for the '08 season...... I need something that is goign to produce about 450-500 whp.
For this setup what do you personally recomend....hopefull less than 900$$$.
96 GSR-T
Aug 16, 2007 04:18 AM
Schister66
Oct 26, 2006 12:55 PM
mrimmortal01
Feb 13, 2006 05:22 PM
SwedBoy2999
Oct 29, 2005 10:05 AM
slammed00si
Jun 2, 2004 12:48 PM
