can i use a d-series power steering pump on my 94 civic four door with a b18b1? HELP
Old Oct 13, 2006 | 05:01 AM
Orangecivic251's Avatar
Default can i use a d-series power steering pump on my 94 civic four door with a b18b1? HELP
i have a 94 four door that i just put a b18b1 in and i have a crv pump but that doesn't match the power steering line end fitting. so i was curious if i could just buy some brackets and make it work
Old Oct 13, 2006 | 10:12 AM
Default Re: can i use a d-series power steering pump on my 94 civic four door with a b18b1? HELP (OrangeCivi
bump
Old Oct 13, 2006 | 10:24 AM
itsjdmbradyo!'s Avatar
well i wouldnt think the pump would be vehicle specific as long as the lines fit. so you should be fine.
Old Oct 16, 2006 | 06:37 AM
the line fits i just can't figure out what brackets to use
Old Oct 16, 2006 | 06:40 AM
stackz's Avatar
at the jetties fishin'
Community Builder
your b1 swap didnt have the ps brackets still attached to it?? they are basically worthless, dont understand why anyone would remove them lol.
Old Oct 16, 2006 | 08:22 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz &raquo;</TD></TR><TR><TD CLASS="quote">your b1 swap didnt have the ps brackets still attached to it?? they are basically worthless, dont understand why anyone would remove them lol.</TD></TR></TABLE> most people remove them to clean up the apperance of the motor.
but i dunno maybe check your local junkyard for ab18 bracket and a d series bracket and see if either one works, if not, just get a b18 pump from the junkyard.
Old Oct 16, 2006 | 08:43 AM
the bracket isn't on there cause it's on my teg ith ab20 and i kept all my p/s the b18b1 is in my four door
Old Oct 16, 2006 | 09:29 AM
EgSalad's Avatar
Heres an easy fix - use your single cam PS pump, then use a p72 upper PS mount, and a P54 (ls/gs) lower PS mount. Done deal.
Old Oct 16, 2006 | 09:31 AM
fmrprojects's Avatar
Default Re: (EgSalad)
only if you were local. i have the brackets and the pump.
Old Oct 16, 2006 | 09:34 AM
i would need those brackets by tommorrow isn't gonna happen. i guess i'm just gonna use the crv pump and bracket and cut and weld the line to work
Piglet
Jul 9, 2016 04:55 PM
khailon
May 7, 2011 10:49 AM
mister_ej2
Apr 5, 2008 06:17 PM
JussHatched
Apr 24, 2006 07:53 AM
kuelerz
Sep 24, 2002 10:16 AM
