can i use a d-series power steering pump on my 94 civic four door with a b18b1? HELP
i have a 94 four door that i just put a b18b1 in and i have a crv pump but that doesn't match the power steering line end fitting. so i was curious if i could just buy some brackets and make it work
Re: can i use a d-series power steering pump on my 94 civic four door with a b18b1? HELP (OrangeCivi
well i wouldnt think the pump would be vehicle specific as long as the lines fit. so you should be fine.
the line fits i just can't figure out what brackets to use
at the jetties fishin'
your b1 swap didnt have the ps brackets still attached to it?? they are basically worthless, dont understand why anyone would remove them lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stackz »</TD></TR><TR><TD CLASS="quote">your b1 swap didnt have the ps brackets still attached to it?? they are basically worthless, dont understand why anyone would remove them lol.</TD></TR></TABLE> most people remove them to clean up the apperance of the motor.
but i dunno maybe check your local junkyard for ab18 bracket and a d series bracket and see if either one works, if not, just get a b18 pump from the junkyard.
the bracket isn't on there cause it's on my teg ith ab20 and i kept all my p/s the b18b1 is in my four door
i would need those brackets by tommorrow isn't gonna happen. i guess i'm just gonna use the crv pump and bracket and cut and weld the line to work
Piglet
07-09-2016 04:55 PM
mister_ej2
04-05-2008 06:17 PM
JussHatched
04-24-2006 07:53 AM
