Bump Stop
I am not sure if this may be the reason why my car bounces so much after intalling my new coil overs, but I left the bump stops as they were and didn't cut them in half, could this be the reason why my car bounces like a basket ball? I tested the shocks and they are fine I push them down and they come right back up. Can anyone help me out with this one?
oem shocks or aftermarket? How low are your coil overs set? If you have stock shocks they may not be stiff enough to stop your car from bouncing...
edit: didn't you just post this?
https://honda-tech.com/zerothread?id=177328
[Modified by p0pe, 4:19 PM 5/3/2002]
If still using unaltered bumpstops, generally lowering even the slightest amount will make your car basically sit on them. When lowering, it's usually good to either cut them, or get some bumpstops (from Truechoice) that are shorter. Riding the bumpstops will make your car ride like utter ****.
you can try putting zip-ties on the shock shaft and see if it gets pressed all the way up the shaft (not my tip, stole it from someone here on HT). this will let you know if the shock is bottoming out on the bump stop.
I removed the Bump Stop the car rides alot better. I bounces a little, but I can deal with it until I get some more money to do it right. Thanks Everyone for your Help.
whoa, dont REMOVE the bump stop, cut it, you need it there so when the suspension fully compresses you dont destroy the shock by blowing out through it......
BWAHAHAHAAHHAAAHAHAHHAHAHAHAHHAHAHA!!!!!!!!!!!!!!! !!!!!!!!!!!!!! Pray to god you didnt throw them out....
j00clown
Suspension & Brakes
Jul 7, 2007 10:11 PM
