tranny allignment dificulties
Old Oct 6, 2006 | 08:59 AM
Eucalyptus lude's Avatar
Default tranny allignment dificulties
Im puttingmy h22 back in and am having trouble alligning everyting properly. I can get hte tranny about 1/2 inch away form motor all around, but it seems like somehting in the shafts is not lining up. Im going to recheck hte clutch agian today to make sure its alligned correctly wiht hte exedy supplied tool. Any other suggestions? Also is it possible to insert the motr back in from the top withthe tranny bolted up, ive removed mostly everything from the engine bay so far.
Old Oct 6, 2006 | 09:03 AM
MadCityLude
Guest
Posts: n/a
Default Re: tranny allignment dificulties (Eucalyptus lude)
The exedy tool is crap. You need to rap the very end in electrical tape till it is the same size as the hole in the crank. Then set it in. I had the same issue 2 days ago. The tip of the alignment tool is too small.
Old Oct 6, 2006 | 09:33 AM
Hawkze_2.3's Avatar
Default Re: tranny allignment dificulties (LudeFanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeFanatic &raquo;</TD></TR><TR><TD CLASS="quote">The exedy tool is crap. You need to rap the very end in electrical tape till it is the same size as the hole in the crank. Then set it in. I had the same issue 2 days ago. The tip of the alignment tool is too small.</TD></TR></TABLE>
Yep, always inspect parts before the actual install so you can avoid these kinds of things. I had to put electrical tape on mine too.
Old Oct 6, 2006 | 09:39 AM
Default Re: tranny allignment dificulties (Hawkze_2.3)
Im lucky cuz i havent bolted the tranny to motor yet, its still outside the car. Is it possible ot isnert the motor wiht tranny wen there bolted up from the top of the enginebay?
goodtrouble
Jun 27, 2008 05:28 PM
BoltonGSR
Jan 27, 2007 11:52 AM
neo_
Dec 8, 2006 03:57 PM
maxxd97
Apr 17, 2004 07:53 AM
94si94cx
Oct 1, 2003 10:15 AM
