Please explain how this MBC works!!!
Old Sep 30, 2006 | 04:59 PM
yeah_its_boosted's Avatar
* B A N N E D *
Default Please explain how this MBC works!!!
I need help hooking up this MBC. These are the two parts that were included and I want to know if any one has used a similar MBC. I dont know what the "T" part is but I hooked the left part up both ways, between my compressor housing and the waste gate and I hit the boost cut both times. I have a 1/2 bar spring so somebody tell me how to hook this up please!!!
I numbered the ports to make explaination easier.
Old Sep 30, 2006 | 06:58 PM
* B A N N E D *
Default Re: Please explain how this MBC works!!! (yeah_its_boosted)
Anybody! Everybody!
Old Sep 30, 2006 | 07:18 PM
95jeremie's Avatar
ok just to help you out i will give it a try... once again a TRY
#1- from vacuum source
#2- to waste gate
#3/4/5 looks to be a T to T off of a vacuum source if you have a vacuum manifold just use that and don't worry about using the T.
If you do use the T
#3- from vacuum source
#5- to the other side of the vacuum source
#4- to the waste gate
hope this helps. i am in the middle of building my kit now and have done research for the past year or so... that is what i THINK. I don't KNOW. so don't get all pissed off if I'm wrong. hopefully someone else can Post to help out.
Old Sep 30, 2006 | 07:53 PM
DontBlink's Avatar
Default Re: Please explain how this MBC works!!! (95jeremie)
the block(on the right in your picture) with the arrow goes in line to your wastegate(#3 and #5) the arrow points toward the wastegate(as per the instructions on the side of the block).
take a vacuum line from #4 to Number #1 on the controller
#2 is a bleed it stays open
Old Sep 30, 2006 | 08:38 PM
95jeremie's Avatar
Default Re: Please explain how this MBC works!!! (DontBlink)
wow that's cool as hell for a MBC i don't rely know to much about them i went ahead and got a AVC-R they are the ****!
thanks DontBlink for the correct info
Old Sep 30, 2006 | 09:11 PM
SOHC_MShue's Avatar
yea thats the incabin style. One of the nipples on the controller like he sais just vents back to the engine bay. Its pretty nice.
Old Sep 30, 2006 | 09:17 PM
* B A N N E D *
So it should be something like this if I'm using the port on my turbo as a pressure source, right? It's weird though, if I blow into port 3 air barely passed but port 4 and 5 flow freely.
Old Sep 30, 2006 | 09:52 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yeah_its_boosted &raquo;</TD></TR><TR><TD CLASS="quote">So it should be something like this if I'm using the port on my turbo as a pressure source, right? It's weird though, if I blow into port 3 air barely passed but port 4 and 5 flow freely.
yea that should be right. Maybe something is clogged up in there. Is it used?
Old Sep 30, 2006 | 10:19 PM
* B A N N E D *
Default Re: Please explain how this MBC works!!! (SOHC_MShue)
Nope not used, but if it is clogged I can always take it apart, it looks simple enough. So I can mount the MBC in the cab of the car? Thats cool.
Old Oct 1, 2006 | 12:43 PM
Garage 808 Hatch's Avatar
looks like a basic dual stage controller, these guys semm to have u covered
Old Oct 1, 2006 | 02:22 PM
y7turbo's Avatar
Default Re: (Garage 808 Hatch)
http://www.turbosmart.com.au/index.php?id=43
its a knock-off turbosmart boost controller.
i had one but it had different stickers on it so im sure it was from a different seller.
tip: keep an eye on the boost gauge, mine had horrible boost creep. its now in the trash.
hope you have better luck.
Old Oct 1, 2006 | 03:29 PM
* B A N N E D *
Default Re: (y7turbo)
Thanks guys! Thats all I needed!
b18psi
Aug 20, 2018 06:05 AM
Luke G.
Sep 14, 2010 08:45 AM
hatchyboy89
Apr 21, 2006 08:14 PM
TURBO B
Jun 11, 2003 11:34 AM
Cramerox
Jul 16, 2002 10:22 AM
