tial wategate vacuum source question
Old Sep 12, 2010 | 02:34 PM
Luke G.'s Avatar
Default tial wategate vacuum source question
Can i use the top banjo bolt on my wastegate as the vacuum source? My side one is to close to the manifold and wont fit. And when installing the manual boost controller should i just T into that one line going to the wastegate?
Old Sep 12, 2010 | 02:54 PM
Redline130's Avatar
Default Re: tial wategate vacuum source question
You need to use the side port of the wastegate, assuming you are using a single stage boost controller.
Yes, you tee it into the vacuum line between the wastegate and boost reference source.
Old Sep 12, 2010 | 04:06 PM
Luke G.'s Avatar
ok, so i T into the line that goes from my vacuum manifold to my wastegate right?
Old Sep 12, 2010 | 05:34 PM
welfarepc's Avatar
waste gates dont use a vacuum source they use a positive pressure source.
tap your compressor housing and use that to provide pressure to the waste gate.
Old Sep 12, 2010 | 06:41 PM
PaddingtonBear's Avatar
The vacuum manifold you have is probably tee'd off your brake booster line, which IS a vacuum source at idle, but when boost pressure builds in the intake manifold and becomes a positive pressure source, the wastegate works like its supposed to. Compressor housing or IM, doesn't really matter.
Old Sep 13, 2010 | 06:04 AM
dpetro1's Avatar
technically the wg should work either way but the manufactuerer suggest not applying vacuum to the wastegate diaphragm because it could possibly be damaged.
OP, when using an mbc you only use the side port of the wastegate. the top port can be left open.
side port of wastegate to bottom of mbc
side port of mbc to boost source. (vac mani will suffice, just not the "correct" way)
Old Sep 13, 2010 | 02:29 PM
Silva Bullit DC4's Avatar
This is gonna depend on the brand of MBC he's using, as some brands have the inlet fitting on the bottom of the controller, and the outlet fitting on the side.
Old Sep 14, 2010 | 05:08 AM
dpetro1's Avatar
oh, good call. i see hallman is set-up that way
Old Sep 14, 2010 | 08:45 AM
Yup, Hallman & Blox.
I ran the Blox Pro for 2 years, and I was surprised at how solid it holds boost.
tundra2000
Sep 26, 2010 06:42 AM
jetspeedz
Aug 23, 2009 02:21 PM
GsrIntegra789
May 6, 2008 06:05 PM
2muchPSI
Nov 22, 2003 02:34 PM
DIY_Racing
Dec 15, 2002 06:05 PM
