anit-lag "d'valve" does it actually work??
anyone heard of this before? looks very intersting. helps build boost at idle by bypassing turbo & intake at idle... which means no vacuum pressure. so when you hit the gas, your starting at 0psi, instead of -15psi. any one try this out yet??
http://www.shelbycsx.com/csx321/buildup/dvalve.htm
Have you ever watched a boost gauge when you tap the throttle? Its linear with throttle movement. There isnt enough lag to measure without instrumentation.
wickedxboi
Feb 28, 2003 10:21 AM
