CEL HELL
So i just dropped my JDM D15b into a 95 four door. Everything is plugged right, everything is correct. Car loses power when rising in the rpms, speedo goes crazy, tach goes crazy(never had a problem with the b7)
Codes:
10 (IAT Sensor)
14 (IAC Valve)
20 (Electronic Load Detector)
21 and 22 (Vtec isn't hooked up because i have a LX non-vtec wiring harness)
It's almost like mayb a clogged injector or spark problem? I don't know. HELP.
Codes:
10 (IAT Sensor)
14 (IAC Valve)
I don't think its possible but are the IAT and IAT switched around because they are the same plug. ELD possibly that you have a loose or ground not hooked up.
when i swappd a d15b into my car i was throwin IAT,vtec and other cells also. i replaced all these parts but was still throwin the cell.. realized the ecu wiring wasnt fully connected.. just a thought before you risk wastin money on stuff not needed like me..
I'm one for testing it with a known working IACV. This way you can tell if you got a ground problem or plug problem someplace or if you simply bought a motor that has some **** wrong with it. At least find out the resistance that the object creates and do an ohmz reading and make sure it's reading that.
