Oil Question.
Ok so I just bought a crx with a b16 swap in it. I noticed that it had a small oil leak after I bought it. It's not bad and its leaking off the oil pan. Well when I cheked the dip stick it was really frickin low. So I went to the parts store and bought a quart of 10-30 sythetic blend. The thing is I have no idea what kind of oil was in there before. Some of my friends told me it could be really bad to mix that with what I think is regular oil in it. I haven't driven it much after this. Did I mess up by putting synthetic in this motor? If so if I do an oil change will everything be ok after? Thanks
Don't freak out, it won't cause any problems. What will be a problem is being low on oil, this is a big problem. so FIX THE LEAK, and do your oil change.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Like Hondas »</TD></TR><TR><TD CLASS="quote">Alrght thanks. As for the leak I'm thinking he cross threaded the bolt on the oil pan... Is there any other fix other than a new oil pan?</TD></TR></TABLE>
you can put an oversized plug in it if you dont already have one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Like Hondas »</TD></TR><TR><TD CLASS="quote">Some of my friends told me it could be really bad to mix that with what I think is regular oil in it.</TD></TR></TABLE>
it doesnt make a difference...what do you think a synthetic blend is?
check all the 10mm bolts on the pan first...its possible the leak is from there
yes they make oversize drain plugs, or if its really stripped a piggy back plug. it will have threads on the outside that will cut new threads in the pan and it has a hole in the center where a smaller drain plug goes this way you only remove the center plug when changing the oil as not to mess up the pans threads anymore.
