Oil pan Fitting weld
Old Sep 23, 2006 | 04:14 PM
sporty240's Avatar
Default Oil pan Fitting weld
Here is a drain fitting that I tried to weld to my oilpan, I used a century 125gs flux core welder
and the inside, looks like it melted some
the fitting is a galvanized steel barbed fitting with pipe thread on the other end, so after I used a 3/4" hole saw bit I just screwed it in my oilpan, it was pretty secure. Now my question is how good or bad is my weld? should I go over it with some JB weld? weld inside too?
Old Sep 23, 2006 | 04:23 PM
Flashmn's Avatar
Default Re: Oil pan Fitting weld (sporty240)
sorry man, but your weld looks horrible, I hope it doesnt leak, I'd get it redone with a tig somewhere.
Old Sep 23, 2006 | 04:33 PM
Lamchop0000's Avatar
that doesn't look too good
Old Sep 23, 2006 | 04:40 PM
RCautoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 &raquo;</TD></TR><TR><TD CLASS="quote"> is a galvanized steel</TD></TR></TABLE>
You do know the fumes from that can do you some pretty bad harm.
Old Sep 23, 2006 | 06:34 PM
SMSP's Avatar
Throw away that flux core wire if you plan to weld stuff to sheet metal. Buy/rent a bottle of gas.
Old Sep 23, 2006 | 11:26 PM
sporty240's Avatar
Default Re: Oil pan Fitting weld (SMSP)
how much is it to get a bottle of gas and what size?
Old Sep 24, 2006 | 07:40 AM
ManBearPig4silly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 &raquo;</TD></TR><TR><TD CLASS="quote">how much is it to get a bottle of gas and what size?</TD></TR></TABLE>
it will take more than that. You will have to covert your flux core welder to use gas. ie you need a gas solenoid. I highly doubt that weld will hold oil. Expect it to start leaking very soon.
Your best bet is to just cut it off and start over with a new fitting and a new weld. If you try to go over that crap nothing good will come of it.
PS. JB weld probably will leak as well.
Old Sep 24, 2006 | 08:39 AM
C_H_A_D's Avatar
Default Re: Oil pan Fitting weld (ManBearPig4silly)
I bet there is somebody on H-T that could redo it for you.
Old Sep 24, 2006 | 10:25 AM
Snafubmx234's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ManBearPig4silly &raquo;</TD></TR><TR><TD CLASS="quote">it will take more than that. You will have to covert your flux core welder to use gas. ie you need a gas solenoid. I highly doubt that weld will hold oil. Expect it to start leaking very soon.
PS. JB weld probably will leak as well. </TD></TR></TABLE>
Depends on the flux core welder. Many of them out there now (besides the HF flux and what not) already come with everything to hook up the gas. All you need to do is buy a regulator, buy/rent a tank, get a spool or wire and flip the polarity.
That "might" hold. i'd throw a quick layer of JBweld on it. JB weld, done properly, will not leak. I've used it on ~8 setups, most of which have been around for a few years. None have leaked.
Old Sep 24, 2006 | 07:35 PM
sporty240's Avatar
Default Re: Oil pan Fitting weld (Snafubmx234)
yea my welder comes with a gas hookup,
well I welded it more and threw some JB on it inside and out to seal up the weld, its not just welded its theaded/screwed in too so I think it will hold, thanks for the comments I will need to get the gas soon...
Old Sep 24, 2006 | 07:52 PM
CRXDrew's Avatar
yea not soo good... did you prep it at all?
heck... I've done JBweld all by its lonesome on my car b4. +2 years and counting on another car.
Old Sep 25, 2006 | 09:08 AM
VRD^don's Avatar
Default Re: (CRXDrew)
looks like u didnt clean it good enough...
Old Sep 25, 2006 | 03:53 PM
sporty240's Avatar
Default Re: (k_motor)
preping? I wiped it down with a paper towel...
Old Sep 26, 2006 | 04:39 AM
Flashmn's Avatar
Default Re: (sporty240)
you have to sand the paint off.
Old Sep 26, 2006 | 11:09 AM
CRXDrew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 &raquo;</TD></TR><TR><TD CLASS="quote">preping? I wiped it down with a paper towel...</TD></TR></TABLE>
there is your problem.
sand to bare metal then acetone. I would do that over from the beginning if I were you.
Old Sep 28, 2006 | 06:33 AM
CBURKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporty240 &raquo;</TD></TR><TR><TD CLASS="quote">yea my welder comes with a gas hookup,
well I welded it more and threw some JB on it inside and out to seal up the weld, its not just welded its threaded/screwed in too so I think it will hold, thanks for the comments I will need to get the gas soon...</TD></TR></TABLE>
You need to get that JB weld off the inside of the pan. If any of it falls off in will get in the oil and the sucker will ether suck it up or clog it.
skiwithcars
Welding / Fabrication
Jun 29, 2006 01:38 PM
livinlow
Mar 6, 2005 10:52 PM
swlabhot
Sep 27, 2004 03:06 PM
RyanAutry
May 6, 2003 12:37 PM
asianspeed
Jan 27, 2003 06:26 PM
