is this a good place for oil return line?
Old Jan 27, 2003 | 05:55 PM
asianspeed's Avatar
Default is this a good place for oil return line?
I'm about to tap my oil pan...but I wanted to get a few comments first. I'm wondering a couple things:
1) Is this a good place to drill the oil pan?
2) Would it be better to drill a hole and put the flange on the inside of the oil pan and have the pipe sticking out. Then jb weld that on the outside of the pan.
- or -
Would it be better to drill a hole and put the flange on the outside of the pan. And try and jb weld it on the inside?
I'm kind of leaning toward putting the flange on the inside, only because I think I would be able to get a better seal. What do you people think?
Old Jan 27, 2003 | 06:10 PM
KC GSR's Avatar
Default Re: is this a good place for oil return line? (asianspeed)
it all depends on how your dp bends around your oil pan...for example, if you are using the drag 3 dp, I would put the return fitting right before the shallow end starts to get deep
Old Jan 27, 2003 | 06:14 PM
niedejb's Avatar
Default Re: is this a good place for oil return line? (KC GSR)
Better move to one side or the other of that bolt hole on the pan or you'll never have access to it.
Old Jan 27, 2003 | 06:26 PM
asianspeed's Avatar
Ok, I'll drill closer to the shallow area. The only reason I had it so far out was becuase of the support that is on the inside of the pan...I was trying to avoid that.
myessay
Feb 10, 2012 04:22 PM
Sinner
Oct 8, 2004 09:21 AM
shadow103rd
May 12, 2004 11:55 AM
2SLO
Dec 18, 2003 01:15 PM
420aNT
Mar 9, 2003 10:26 PM
