Tuned on 6psi now up to 9psi
Old Sep 22, 2006 | 10:12 PM
1Quikgsr's Avatar
Default Tuned on 6psi now up to 9psi
when the motor got tuned it was on 6psi made 296whp 194wtq that was around 100 degrees, now i just got back from taken the hatch out in 2 weeks and its right unded 10psi it was cold outside i say low 70 hight 60 degrees how does it go from 6 to 9 psi? car feels good btw
Old Sep 22, 2006 | 10:16 PM
1Quikgsr's Avatar
Default Re: Tuned on 6psi now up to 9psi (moops vs moors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moops vs moors &raquo;</TD></TR><TR><TD CLASS="quote">what's your wastegate (integral/external) / boost controller setup?
what boost guage are you using?</TD></TR></TABLE>
its a tial wg no boost controler autometer gauge at hot nights it would read at 6
Old Sep 22, 2006 | 10:23 PM
komat's Avatar
Default Re: Tuned on 6psi now up to 9psi (1Quikgsr)
air is more dense when its cold
you running a sc61 at 6psi with a 38mm wastegate?
Old Sep 22, 2006 | 10:24 PM
1Quikgsr's Avatar
Default Re: Tuned on 6psi now up to 9psi (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">air is more dense when its cold
you running a sc61 at 6psi with a 38mm wastegate?</TD></TR></TABLE>
yup on a 11.3 comp
Old Sep 22, 2006 | 10:25 PM
komat's Avatar
hmmm i was told that anything lower then 10psi with a 38mm will spike on a sc61
damn it! i need to get rid of my 1bar spring
PINKS
Jan 22, 2007 01:12 PM
blackcivic44
Feb 1, 2005 07:45 PM
done
Dec 12, 2004 07:20 PM
toxicshit
Aug 15, 2004 12:14 PM
trbob16a
Nov 18, 2003 04:55 PM
