vtec just stop working????
Old Sep 21, 2006 | 04:55 PM
streetracerjoey210's Avatar
Default vtec just stop working????
well a slight problem? from one day to the next my vtec stop working, why.
it always kicked in at 5,000 rpm. but from one day to next it just stoped. no mods were done. I removed vtec solenoid. clean out screen, air blowed all oil out check seals all good. what else could i do to solve problem.
Old Sep 21, 2006 | 04:59 PM
Luserkid's Avatar
Default Re: vtec just stop working???? (streetracerjoey210)
Do you have oil?
Old Sep 21, 2006 | 05:00 PM
yes i do,
Old Sep 21, 2006 | 05:03 PM
-Gambit-'s Avatar
bad ground, or a lose wire???
Old Sep 21, 2006 | 05:05 PM
Luserkid's Avatar
Get an oil pressure gauge and see what your readings are. Also check all your wiring for your VTEC and oil sensor.
Old Sep 21, 2006 | 05:09 PM
haji's Avatar
Default Re: vtec just stop working???? (Luserkid)
wat kinda v-tec is it? and is the car swaped if so how is vtec wired... to the ecu or some k-mart jiffly lube tech blessed u?.. i-vtec or b or h series..... for b or h series motors... it could be simple as dirty oil believe it or not or not enough oil..... then check the connecor to the soleniod if its recieving a ground signal from the ecu.... if not check for the obious first (broken wires...loose connections...ect.) but before u do that go to the ecu and back probe the pin for the vtec wire make sure the ecu is doing its job,
Old Sep 21, 2006 | 05:12 PM
ok check it out. speed sensor works/ so does my speedo in dash.
oil pressure is good. no oil light on dash. only when startup.
check wires good. good ground. tested vtec noid removed added 12 volts it clicked. so thats works. ecu is a stock p28 no cel light for that problem. just i know i have a bad o2. but it worked fine.vtec kicked in no problem. what else. please car runs like crap..................................
Old Sep 21, 2006 | 05:14 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracerjoey210 &raquo;</TD></TR><TR><TD CLASS="quote">
oil pressure is good. no oil light on dash. only when startup.</TD></TR></TABLE>
Dummy light only comes on when your under, i think, 10psi. It wont tell you if your running good oil pressure. VTEC needs 60psi to activate correctly.
Old Sep 21, 2006 | 05:15 PM
1.6 ex motor -p28 stock.
vx motor pulled out about a year ago. vtec was pre wired.
Old Sep 21, 2006 | 05:17 PM
hmmm. should i remove oil press sensor, clean replace
Old Sep 21, 2006 | 06:16 PM
what else could be done
Old Sep 23, 2006 | 03:53 PM
haji's Avatar
k but is the ecu sending a signal to the tec soleniod?.... if everything checks out good...change the oil..... it sounds dumb but sometimes dirty oil, or too thin oil will bite u in the ***.
h22silvia
Nov 9, 2006 07:59 AM
B20_SI_CRX
21
Jun 8, 2005 10:03 AM
05 S2K Stoner
Oct 28, 2004 06:39 PM
VTECPowerdSi
Oct 24, 2004 07:18 PM
spoonef
Feb 28, 2003 10:01 AM
