Motor Options
ok so i have about $4k to use to do whatever motor swap i want, right now i have a 2000 civic hatch automatic stock motor, what do you guys think is my best option, keeping in mind i want something nice and clean and reliable, thanks
Im kinda of in the same boat as you I think im gonna go 5 speed conversion and then get a turbo. i think it would be alot more fun that way. But I'm no expert.
Yeah definately going 5 speed, was thinking a clean b16 with a nice intake and valve cover and header, and maybe paint the engine bay and do a mild tuck, either that or a built single cam with a JRSC, cause i can pick one up from my friend for 600, other than that i don't really know what else i can do with 4, too low for k-series
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MWIMPORTS.NET »</TD></TR><TR><TD CLASS="quote">Yeah definately going 5 speed, was thinking a clean b16 with a nice intake and valve cover and header, and maybe paint the engine bay and do a mild tuck, either that or a built single cam with a JRSC, cause i can pick one up from my friend for 600, other than that i don't really know what else i can do with 4, too low for k-series
just go for a gsr...dont waste your time with a b16 or a jrsc...haha
</TD></TR></TABLE>just go for a gsr...dont waste your time with a b16 or a jrsc...haha
GSR block, PR3 head, Type r valvetrain or equivalent, R cams, Intake manifold.
Definately get a Y21 or s80 with LSD,
Now that you have spent about 2200.00 replace all gaskets and seals and have around 1500.00 for boost after the misc small stuff you will end up replacing.
Should put you somewhere in the 14's.
Might want to think about an LS 5th gear though because I love the hell out of 4.4 gearing but this isn't my daily driver either. I also run a minimum of 91 octane because we don't have 93 here. But 105 octane at the track sure makes a difference.
You wanted opinions so there you go.
Originally Posted by Ricey McRicerton
Well since this gets asked almost daily, me and BauleyCivic have decided that making a thread to showcase, if you will, the swaps.
Some intro swap information
Switching OBD motors
Many people think that swapping in a pre OBDI motor into their 92+ Civic is a good idea. I disagree. First, you'll have to swap the car from OBDI to OBD0 ot try and change the motor to OBDI. If you get a swap older than a 1991, you have to deal with the cable to hydro tranny conversion. The 1992-1993 Integra is the oddball swap of the bunch, being OBD1 and cable tranny. Your stock Civic has a hydraulic transmission.
Swapping from OBDII to OBDI is a common thing more and more now. Although the idea is quite good, it has flaws. If you use a jumper harness, it is very difficult to get the ECM to fit back in it's original location. Also, unless you feel like changing things back at inspection time, it's going to be impossible to pass in some areas. Now places are implementing OBDII testing that will have the tester plug a computer into your OBDII port to check for legality (no pulling the check engine light bulbs anymore to pass).
General swap info and tips
This could be better covered by someone with more swap experience, but I'll put in my $.02. Do it from the top. Just because more people have access to the tools and locations where putting in a swap from the top is easier. Also, make sure you have some way to crack the axle nuts loose. Air tools are a lifesaver when you have to turn bolts in a job like this, as is a torque wrench and a GOOD set of sockets.
If you can follow directions on here and unbolt things and rebolt them with a little wiring, you can do a swap.
A special thanks goes out to JDMlyfestyle for this thread https://honda-tech.com/zerothread?id=983454
JDM Swaps
Honestly, unless these come from a friend in Japan, you're taking a gamble every time. You have no real way to know how many miles are on the engine, nor how it was treated. Just keep that in mind. It has not been proven (no matter how many claims) that these JDM motors make any more HP.
Where to find them
First of all, if you are looking for a USDM motor, I'll suggest local junkyards. They are probally your best bet, as you can look at what you're getting instead of having to order it. Many people on here have bough swaps online, and they have posted their experiences in this thread:
https://honda-tech.com/zerothread?id=50010
Possible Swaps
Now before someone jumps on me and says anything is possible with enough time and money, I know. These are going to be fairly straightforward options with the pros/cons.
<U>D series swaps</U>
These are fairly inexpensive and come in a variety of Civics. IMHO, these are the easiest swaps to drop in. I also don't want to hear a bunch of whining about the opinions on power levels. Of course there are going to be some exceptions to the rule.
Pros
Inexpensive
Decent potential (200 whp or so on stock internals)
OEM parts are cheap
More than enough for most people
The best D series come with ~130 hp tops
Optional factory LSD in the JDM D15B
Cons
Not as much potential as some other motors
Transmission not geared for accelleration
Don't respond to bolt ons well
Only way to get real power out of them is FI
<U>B16</U>
These can be found in the JDM SIR and SIRII (among other JDM cars, which I don't claim to know all of which it came in) as well as the USDM 99-00 SI (EM1) and the 99-00 Canadian SIR.
Pros
160 hp stock
High RPM power
Fairly inexpensive
Good transmission
DOHC VTEC
Cons
113ft/lbs torque (very little more than a D16z6 stock)
Without knowing what you're looking for you can end up with a high mileage JDM model
Under 4k or so it feels just like a D16
<U>B18B</u>
This is the motor in the non Type-R and non GSR Integra.
Pros
Good torque for a 1.8L (127 ft/lbs)
Inexpensive (even cheaper than a B16)
142 hp (more than any stock D series)
Boost heads love them
Cons
No VTEC
Longest B series transmission
<U>B18C1 (or JDM B18C)</U>
These come out of an Integra GSR.
Pros
Good Hp and TQ numbers (170, 121 ft/lbs respectively)
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Becoming moreso as people keep scooping them up
Slighty longer tranny than the ITR and B16
<U>B18C5 (or JDM B18C)</U>
This is found in the Integra Type-R. IMHO this is the best swap for a Civic.
Pros
GREAT HP and TQ numbers (195 and 134 ft/lbs)
High revving
Hand built motor from Honda
Best transmission for a B series from the factory
Red valve cover
Cons
EXPENSIVE
If JDM ITR is used, the 36mm axle 32mm hub problems occur
<U>B16B</U>
This is the motor found in the Civic Type R found all over the world.
Pros
185 hp 117 ft/lbs
High revving
Good top end power
Red valve cover
Cons
Expensive- almost as much as an ITR for lower performance
Very little torque still, have to rev the motor to make power
<U>B20</U>
Pros
Great torque (133 ft/lbs)
good boost motors
inexpensive
B20z=146hp
Cons
Thin cylinder walls
Have to peice together a swap for a Civic (can't drop it in with a B20 tranny)
Won't pass BAR (light truck motor in a car)
Low hp in the B20b(126 hp)
<U>H22/JDM F20B</U>
Pros
200 hp
H22=156 ft/lbs torque
F20B=145 ft/lbs torque
Great torque
DONT WEIGH THAT MUCH MORE THAN A B SWAP!!
https://honda-tech.com/zerothread?id=684550
Cons
Harder to install than a B/D motor
transmission feel is vague IMHO
Less info out there for the swap (aka, less experience as they are less common)
Price of swap is comperable to a B18C5 after everything is said and done (mounts, etc)
<U>K20</U>
This can be found in the new EP3, the RSX (base and Type S) as well as other cars across the world (RSX R, etc). This is the future of the swap IMHO. There is a writeup on installing one of these in one issue of Sport Compact Car magazine (June 2004 I *think*)
Pros
200 hp 158 ft/lbs torque (RSX R)
I-VTEC
Respond VERY well to bolt ons
6 speed transmission
Most have very low miles
Cons
Still super expensive
More difficult swap than a B or D
Well, there you have it people. I've outlined some of the pros cons on some of the most popular swaps.
Check out the FAQ thread for more info on how to install them.
https://honda-tech.com/zerothread?id=642479
Most of these HP/TQ numbers were taken from Hmotors online if I didn't know them. Don't bite my head off if they aern't correct. I don't claim to be a walking encyclopedia, so I have had some help.
JDM Swaps
Where to find them
Possible Swaps
Pros
Inexpensive
OEM parts are cheap
Cons
<U>B16</U>
Pros
160 hp stock
High RPM power
Fairly inexpensive
Good transmission
DOHC VTEC
Cons
<U>B18B</u>
Pros
Cons
No VTEC
Pros
DOHC VTEC
Tons of potential
High revving
Cons
Expensive
Pros
High revving
Red valve cover
Cons
EXPENSIVE
<U>B16B</U>
Pros
185 hp 117 ft/lbs
High revving
Good top end power
Red valve cover
Cons
<U>B20</U>
Pros
good boost motors
inexpensive
B20z=146hp
Cons
Thin cylinder walls
<U>H22/JDM F20B</U>
Pros
200 hp
Great torque
Cons
<U>K20</U>
Pros
I-VTEC
Cons
If I was in your exact situation it'd be first automatic to manual conversion on your car, then turbo your stock motor. Hell, for 4k you'll probably even be able to afford forged internals & semi-build your engine to really pump up the turbo setup.
JDM_ES2chick
Honda Civic (2001 - 2005)
14
Nov 20, 2009 02:36 PM
a1320honda
Oct 16, 2007 10:35 PM
mycivichb
Oct 30, 2004 04:51 AM
