dpi-mpi obd0-obd1
Old Sep 20, 2006 | 09:33 PM
skoodles2k6's Avatar
Default dpi-mpi obd0-obd1
ok finally got my harness's out and started working on wiring them up for my ls swap.
and getting a little confused. doing this based off this site i found. http://www.pgmfi.org/twiki/bin...-OBD1
first i took the injector harness off my ob1 ls harness and connected the yellow/black wire off the obd0 harness to the gray 8 plug wich tied all the yellow/black wires of the injectors off the obd1 harness.
1st question what do i do with the solid yellow wire wich was in the same plug as the yellow/black on the obd0 harness.
then I assume run the colored wires off my injectors straight to the ecu for the signal. since im using obd1 injectors i dont belive i need the resistor box.
now repinning the plug for my dizzy and theres 2 plugs on each harness
on obd0 harness theres 5 wires in one plug and 2 on the other
on obd1 harness theres 7 wires on one plug and 2 on the other
from reading that site it says color match them but nothing about the extra 2 wires.
im sure theres still more different plugs i gotta convert over or extend i ben reading i gotta extend some wires but ima have to go back and find out where i read it. so if you got any advice id appreciate it.
Old Sep 20, 2006 | 10:11 PM
Default Re: dpi-mpi obd0-obd1 (skoodles2k6)
ok looking further i realized the solid yellow is one of the injector wires and so is the solid red and just connect the yellow/black wires from the 2 orignal injectors to the gray 8 plug retaining all of them. solved that part my self. now the other wires off my injectors brown and blue i just run straight to the ecu.
Old Sep 21, 2006 | 07:39 AM
anyone else advice on the dizzy plug?
Old Sep 21, 2006 | 07:13 PM
what do i do with the extra 2 wires on the dizzy?
Old Apr 26, 2012 | 11:10 AM
91_ef-forlife's Avatar
You wire them straight to the ecu
Old Apr 26, 2012 | 11:11 AM
24TEN's Avatar
PHANTOM MENACE
5.5 years ago, good job
Old Apr 26, 2012 | 11:42 AM
4drEF's Avatar
Keyboard Humorist
Finally, skoodles2k6 can now get this car back on the road.
Old Apr 26, 2012 | 11:59 AM
TearSDMF89dx's Avatar
very insightful information here now if only you could post through a wormhole this guy could get his information when he needed it
Old Apr 26, 2012 | 03:52 PM
sstupid's Avatar
10 Year Member
BWAHAHAHAHAHAAAAA!!!11!11!!!
heh....heh
hee-hee
89ED
Jan 22, 2017 09:52 AM
teg4life
Oct 14, 2004 11:22 AM
milruner
Sep 19, 2004 12:07 AM
4crx4me
May 18, 2004 08:17 AM
