Internal Wastegate Flapper Arm Bent, Easy fix?
Old Sep 20, 2006 | 05:50 PM
dr_latino999's Avatar
Default Internal Wastegate Flapper Arm Bent, Easy fix?
Big 16G
Can I just bend this straight or do I have to replace it?
If I have to replace it, how would I go about doing this?
This is my first venture with internal gated turbos, so any help will be appreciated.
Old Sep 20, 2006 | 06:14 PM
turbinteg's Avatar
Default Re: Internal Wastegate Flapper Arm Bent, Easy fix? (dr_latino999)
i would just bend it back and make sure it moves freely
Old Sep 20, 2006 | 06:18 PM
Default Re: Internal Wastegate Flapper Arm Bent, Easy fix? (turbinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbinteg &raquo;</TD></TR><TR><TD CLASS="quote">i would just bend it back and make sure it moves freely</TD></TR></TABLE> Hammer it or just whip out the vice-grips and start playing tug of war?
Old Sep 20, 2006 | 06:36 PM
HiProfile's Avatar
It just has to be straight enough not to bind. You usually have a bit of play inside the arm's hole. Just be careful when bending it. Although they use some high quality steel, its still heat cycled enough - at very high temps - to be brittle enough. THEN you're SOL until you replace it.
Old Sep 20, 2006 | 06:54 PM
Default Re: Internal Wastegate Flapper Arm Bent, Easy fix? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">It just has to be straight enough not to bind. You usually have a bit of play inside the arm's hole. Just be careful when bending it. Although they use some high quality steel, its still heat cycled enough - at very high temps - to be brittle enough. THEN you're SOL until you replace it.</TD></TR></TABLE> So I think it will be the vice grips and some nice words of encouragement
Old Sep 21, 2006 | 09:46 PM
mr_hahn73's Avatar
Bend it back the same way it got to that point! Good Luck!
greasemonkee
May 28, 2008 07:58 AM
EH-3
Dec 4, 2005 01:45 AM
vtec.dc2
Aug 31, 2004 06:47 PM
Sohc Driver
Jul 22, 2003 11:39 PM
Cramerox
May 20, 2003 01:27 PM
