Normal for a Tial WG to rotate?
Old Aug 30, 2007 | 04:07 PM
greasemonkee's Avatar
Default Normal for a Tial WG to rotate?
Just noticed the whole diaphragm housing now rotates. It a 44 Tial. Is this typical or should I tear it down for inspection?
Old Aug 30, 2007 | 05:06 PM
TiAL's Avatar
Default Re: Normal for a Tial WG to rotate? (greasemonkee)
get me images
your nut may have come loose
Old Aug 30, 2007 | 05:13 PM
TTT's Avatar
TTT
Default Re: Normal for a Tial WG to rotate? (TiAL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TiAL &raquo;</TD></TR><TR><TD CLASS="quote">your nut may have come loose </TD></TR></TABLE>
I hate it when that happens.
Old Aug 30, 2007 | 05:21 PM
champLSinteg's Avatar
Default Re: Normal for a Tial WG to rotate? (TTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TTT &raquo;</TD></TR><TR><TD CLASS="quote">
I hate it when that happens. </TD></TR></TABLE>
LFAO!
Old Aug 30, 2007 | 05:24 PM
project dc2's Avatar
Default Re: Normal for a Tial WG to rotate? (champLSinteg)
take it apart and tighten the lock nut inside. is your car possibly overboosting because of this ?? it was an issue on one of our street cars that the car would spike to 18 psi on a 11 psi spring. later we found the housing to be loose ( mind you on a brand new tial)
Old Aug 30, 2007 | 06:20 PM
Default Re: Normal for a Tial WG to rotate? (project dc2)
The nut is tight. There is a set screw on the flange portion of the nut that appears to either hold the base of the housing in position or lock the nut in place (removed in pic). Otherwise, there is a bit of a gap under the nut and lower housing. This one has 200 miles on it.
Old Aug 30, 2007 | 11:20 PM
I don't know how many shims were suppose to be on the back side of the housing, but I just added one, now the nut tightens the housing to the valve body. Much better
Old Aug 31, 2007 | 05:17 AM
TiAL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greasemonkee &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how many shims were suppose to be on the back side of the housing, but I just added one, now the nut tightens the housing to the valve body. Much better </TD></TR></TABLE>
that is exactly what you needed to do, we had a few washers come out a little thin, the fix is to add another
Old May 28, 2008 | 07:58 AM
Shockster0429's Avatar
BUMP:
I've got the same issue with my 44mm, how do you remove the diaphragm safely after you remove the 4 set allen headed screws? My whole assembly rotates with the valve around the body 360 degrees.
FastAsleep
Jul 29, 2007 01:03 AM
program
Apr 15, 2006 04:26 AM
turbo*s2k
Nov 25, 2004 06:26 PM
tgreaves
Oct 10, 2003 10:22 PM
KiNG $h!t
Sep 23, 2003 02:08 PM
