Internal Wastegate replacement.
Old Jul 22, 2003 | 12:58 PM
Sohc Driver's Avatar
Default Internal Wastegate replacement.
I currently have a 16g td05 mitsubishi turbo, the current wastegate is set at 10psi but i want to run much lower than that. I recently learned that there are 7psi wastegate actuators that can replace my current actuator. Does anyone have any insight on doing this? I have no idea how to replace my actuator and on top of that....is replacing the actuator the only way to lower boost on an internal wastegate setup?
Khoi
Old Jul 22, 2003 | 04:14 PM
Default Re: Internal Wastegate replacement. (Sohc Driver)
bizzump
Old Jul 22, 2003 | 05:04 PM
stierhund's Avatar
Its not hard to replace the actuators, most have c rings that are a pain to get off w/out the right tools, but it can be done w/pliars... the rest is just bolts attached to the compressor housing and turbine shell. I have no experience replacing them, but I have taken mine (IHI turbo) apart, and its easy to put back together.
Old Jul 22, 2003 | 05:08 PM
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote"> I recently learned that there are 7psi wastegate actuators that can replace my current actuator. </TD></TR></TABLE>
who sells that? I've been looking for the same thing.
Old Jul 22, 2003 | 11:39 PM
Default Re: Internal Wastegate replacement. (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">
who sells that? I've been looking for the same thing.</TD></TR></TABLE>
call..www.cheapturbo.com
Khoi
gsr x civic
Aug 19, 2007 05:46 PM
AutoEuphoria
Sep 30, 2004 06:36 PM
Sohc Driver
Jul 20, 2003 11:31 AM
Nextelbuddy
Jun 9, 2003 10:13 AM
