Tranny ????
Old Sep 17, 2006 | 07:55 PM
hondachris1994's Avatar
Default Tranny ????
I have a b16 j1 cable tranny if I buy a ls cable tranny can I put my b16 1-4 gears in it and will my clutch pressure plate and throwout bearing work in the ls tranny?
Old Sep 17, 2006 | 07:59 PM
cambopheonix56's Avatar
Default Re: Tranny ???? (hondachris1994)
Interesting concept. Not sure if it will work but you should be able to put the ls 5th in your tranny now. That would be easier.
Old Sep 17, 2006 | 08:05 PM
Default Re: Tranny ???? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">Interesting concept. Not sure if it will work but you should be able to put the ls 5th in your tranny now. That would be easier.</TD></TR></TABLE>my tranny is leaking from the bottom previos owner JB welded the bottom but still leaks a lil and ls tranny's are pretty cheap and I want that LS 5th cause my 5th sucks on the highways if u know what I mean
Old Sep 17, 2006 | 08:38 PM
coconutsoldier's Avatar
Default Re: (hondachris1994)
I bet it would work. My friend had a turbo b16 ef hatch and I am pretty sure that is what he did with his trans since his stock b16 cable trans had the infamous 3rd
gear grind. I think this is what he did because he pointed out the same thing you did- about how cheap they are. This was years ago though, so there is a chance I am wrong.
Old Sep 17, 2006 | 08:43 PM
Default Re: (coconutsoldier)
cause I can get a ls tranny for a $100 but its got a 3rd rear grind and my b16 gears are all fine, but I dont want to pull my tranny out and find out that it wont work, cause it takes a gd amount of time and effort to take tranny out and switch gears, especially if it doesnt work
Old Sep 17, 2006 | 08:46 PM
Eran's Avatar
HT White Ops
I hear of people putting ls 5th gears in b16 tranny's all the time, so I don't see why it wouldn't work the other way around.
Old Sep 17, 2006 | 08:47 PM
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">I hear of people putting ls 5th gears in b16 tranny's all the time, so I don't see why it wouldn't work the other way around.</TD></TR></TABLE>but would my clutch fot in the LS?
Old Sep 17, 2006 | 11:42 PM
travisallenn's Avatar
sorry to threadjack but...
if i did a b18 or b16 swap could i still keep my d16y8 tranny on it?
Old Sep 17, 2006 | 11:46 PM
FalkenSiR's Avatar
Default Re: (travisallenn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travisallenn &raquo;</TD></TR><TR><TD CLASS="quote">sorry to threadjack but...
if i did a b18 or b16 swap could i still keep my d16y8 tranny on it? </TD></TR></TABLE>
Absolutely not.
B motors are B series, D motors are D series.
B16/7,8, etc are B series. D15/6 are D series.
Old Sep 18, 2006 | 06:32 PM
someone had 2 try this
Old Sep 18, 2006 | 06:39 PM
Syndacate's Avatar
I'm pretty sure you can.
Or just buy an LS and swap the final drive like sombody else mentioned :-P.
Lemme go find bense.
Old Sep 18, 2006 | 07:03 PM
Default Re: (Syndacate)
or could I buy shorter gears to put in the LS tranny, but would the gears b costly?
Old Sep 19, 2006 | 09:23 AM
bump
Old Sep 19, 2006 | 09:28 AM
Luserkid's Avatar
As long as the 2 transmissions are cable youll be fine to switch gears, diff. and final drives with no prob. As for the clutch its the same thing, Cable clutch for cable trans, hydro clutch for hydro trans.
Old Sep 19, 2006 | 09:37 AM
so my flywheel clutch pressure plate and throwout bearing will fit in the LS with no problems?
Old Sep 19, 2006 | 01:35 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">so my flywheel clutch pressure plate and throwout bearing will fit in the LS with no problems?</TD></TR></TABLE>
Yes.
V8 2 L8
Transmission & Drivetrain
Dec 7, 2008 10:23 AM
hondateg10
Jul 11, 2007 10:19 AM
88cerx
Mar 17, 2005 07:42 PM
c1v1c89h4tch
16
Mar 7, 2005 02:36 PM
blacksol95
Aug 3, 2004 04:16 PM
