Tranny ????
Tranny ????
I have a b16 j1 cable tranny if I buy a ls cable tranny can I put my b16 1-4 gears in it and will my clutch pressure plate and throwout bearing work in the ls tranny?
Re: Tranny ???? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 »</TD></TR><TR><TD CLASS="quote">Interesting concept. Not sure if it will work but you should be able to put the ls 5th in your tranny now. That would be easier.</TD></TR></TABLE>my tranny is leaking from the bottom previos owner JB welded the bottom but still leaks a lil and ls tranny's are pretty cheap and I want that LS 5th cause my 5th sucks on the highways if u know what I mean
Re: (hondachris1994)
I bet it would work. My friend had a turbo b16 ef hatch and I am pretty sure that is what he did with his trans since his stock b16 cable trans had the infamous 3rd
gear grind. I think this is what he did because he pointed out the same thing you did- about how cheap they are. This was years ago though, so there is a chance I am wrong.
Re: (coconutsoldier)
cause I can get a ls tranny for a $100 but its got a 3rd rear grind and my b16 gears are all fine, but I dont want to pull my tranny out and find out that it wont work, cause it takes a gd amount of time and effort to take tranny out and switch gears, especially if it doesnt work
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">I hear of people putting ls 5th gears in b16 tranny's all the time, so I don't see why it wouldn't work the other way around.</TD></TR></TABLE>but would my clutch fot in the LS?
Re: (travisallenn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travisallenn »</TD></TR><TR><TD CLASS="quote">sorry to threadjack but...
if i did a b18 or b16 swap could i still keep my d16y8 tranny on it? </TD></TR></TABLE>
Absolutely not.
B motors are B series, D motors are D series.
B16/7,8, etc are B series. D15/6 are D series.
Absolutely not.
As long as the 2 transmissions are cable youll be fine to switch gears, diff. and final drives with no prob. As for the clutch its the same thing, Cable clutch for cable trans, hydro clutch for hydro trans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 »</TD></TR><TR><TD CLASS="quote">so my flywheel clutch pressure plate and throwout bearing will fit in the LS with no problems?</TD></TR></TABLE>
Yes.
Yes.
88cerx
03-17-2005 07:42 PM
