use an auto ecu?
Old Sep 16, 2006 | 07:01 PM
dustinO's Avatar
Default use an auto ecu?
I bought a JDM D15b that I bought from Superior Trading International, LLC (never buy from the asshats. worst customer service in the world. Took me over a month after paying them to get the motor shipped) anyways....
They shipped me a P08 ecu with the engine. And I just found out from one of the articles on here that it is an automatic ECU. my question is....Will this work with my 5 speed set-up? I have heard It will and It won't?
Old Sep 16, 2006 | 07:25 PM
fucjdm
Guest
Posts: n/a
Default Re: use an auto ecu? (integraca)
it will work but you will get a check engine light... It will be looking for the neutral safety switch
Old Sep 16, 2006 | 08:36 PM
dustinO's Avatar
So the fuel maps and fuel cut off will all be the same
Old Sep 16, 2006 | 11:26 PM
lemon_juice's Avatar
Default Re: (integraca)
if your asking about performance, the ECU will not put you in limp mode for just the automatic CEL.
Old Sep 17, 2006 | 03:08 AM
dustinO's Avatar
cool beans.....thats all I wanted to know
thank you
Old Sep 17, 2006 | 08:26 AM
fucjdm
Guest
Posts: n/a
On the plus side if you know anyone that chips ecus they can remove the auto portion all together
Old Sep 17, 2006 | 09:31 AM
94ex-vtec
Guest
Posts: n/a
Default Re: (chillis)
you wont be able to run vtec either, but it can be chipped to run vtec
Old Sep 17, 2006 | 06:56 PM
dustinO's Avatar
well that thats sort of a problem
to run an eg si ECU whatever the code is. Wouldnt I have to run a 4 wire O2? because I know I can run a 1 wire with my p08. and sense thats what my cx came with it would make it very simple to hook up
Baller111
May 6, 2012 10:02 AM
akouznet
May 24, 2009 06:50 PM
Styler93GSX
Feb 2, 2004 03:28 PM
H22ACiViC
Feb 13, 2002 07:05 PM
