has anyone had this problem??
Old Apr 29, 2002 | 09:27 PM
Speedz's Avatar
Default has anyone had this problem??
http://homepages.wwc.edu/student/krugri/pic2.jpg
http://homepages.wwc.edu/student/krugri/pic1.jpg
water pump has about 30,000 miles on it, i replaced it 2 years ago.
the shaft turns freely, bearing is good.. no shaft play at all.
i've been trying to get my motor tuned after installing the prepped head i finnished building. (port/polish, crower dual valve springs, crower titanium retainers, 3 angle valve job, JG cams, AEM gears)
i've been struggling with my timing belt. trying to get the crank set right and the cams. etc..
i had just bolted everything together after tightening my timing belt tensioner. and took at short test drive around my apartment.. i think i was doing 3k rpm when it came off, but, i had been reving it earlier trying to see how the motor was running.
ARRGGGHHHH!!!!! this is soo frustrating. now i gotta get a new water pump, and install it, and who knows if i damaged my valves yet.. i wont know till i get the new pump on and can turn the motor over.
i'm venting now..
Old Apr 30, 2002 | 06:46 AM
Speedz's Avatar
Default Re: has anyone had this problem?? (Speedz)
ttt
Old Apr 30, 2002 | 12:29 PM
BeerMan's Avatar
My water pump went up yesterday. Left me stranded at work, was not happy.
Old Apr 30, 2002 | 01:07 PM
Speedz's Avatar
Default Re: has anyone had this problem?? (BeerMan)
it just sux because i may have bent a valve
only4cylinders
Apr 8, 2005 12:18 PM
242 Accords
Nov 22, 2004 10:52 PM
tina
Sep 19, 2004 06:05 PM
FortunateFool.
Jul 4, 2003 08:19 PM
af97civic
Jun 10, 2003 01:31 PM
