Timing Belt change problem ..
Old Jul 4, 2003 | 06:53 PM
FortunateFool.'s Avatar
Default Timing Belt change problem ..
Today I changed my timing belt and water pump . Well everything went ok with the water pump, I got the crank lined up to TDC I aligned my cams and stuck 2 punches down through the holes in the top of them to hold them in place(b18b1) so i got the belt on...took the punches out and turned the motor 3 teeth counter clockwise and tighten ...i am now 1 tooth off on my intake side ..Ive tried to re do this like 4 times what am i doing wrong: ( please helps guy ...thanks
Old Jul 4, 2003 | 08:19 PM
DEVIN22CBR's Avatar
Default Re: Timing Belt change problem .. (jcstites)
blast off ....squirt
eatshitbish
Mar 6, 2015 07:23 PM
Stan Koehn
Jul 25, 2009 03:19 PM
supracrx
Feb 17, 2008 09:06 AM
LSVtechnologytur...
May 9, 2005 10:19 PM
