ZEX dry 55 shot on stock B16 questions
Old Sep 13, 2006 | 02:16 PM
DC5ftmfw's Avatar
Default ZEX dry 55 shot on stock B16 questions
Im thinking about putting a 55 shot on my B16A that has an i/h/e and ITR cams. Would it be safe without doing any ECU tuning? Im going to run a step colder NGK plugs and probably pull 2 degrees of timing up top and that be it. My plan is to not spray it until I get it on a dyno and if it's to lean when we spray it there, change the fuel pill to the one used on a 75 shot. Do the ZEX kit's really make it run lean w/ out ECU tuning anyway? I know they have that control box that monitors bottle pressure and that regulates fuel pressure. So are they generally safe enough to run without tuning as long as I have the colder plug? I don't wanna expletive anything up..
Old Sep 13, 2006 | 03:48 PM
JSPECSIR's Avatar
Default Re: ZEX dry 55 shot on stock B16 questions (StevesEKhatch)
you dont have to do anything, put it on and let her rip. you dont have to change timing until you go 65 and 75 shot. once you buy the kit it explains all that in detail in the instructions. have fun i love mine.
Old Sep 13, 2006 | 04:42 PM
Garage 808 Hatch's Avatar
ya, the "fuel" pill lol. its just like a rising rate regulator for a boosted car. i had no probs with my dry kit on my sohc, and zex is setup to be rich
Old Sep 13, 2006 | 08:08 PM
DC5ftmfw's Avatar
Default Re: (Garage 808 Hatch)
thanks guys. That's what I needed to know. I've heard lots of good things about ZEX so Im gonna go with them. So the fuel pill is made to add enough fuel to richen it up and stop it from leaning out?
Old Sep 13, 2006 | 09:22 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default Re: (StevesEKhatch)
Yeah it ups your fuel pressure
You dont need to pull any timing for a lonely 55 shot though. I ran a 75 on my d16a6 for a year with 2* pulled and it ripped hard and loved every second of it
Maybe think of stepping up to a 75, ur motor can take it easily and u dont need to upgrade anything
Old Sep 13, 2006 | 09:48 PM
DC5ftmfw's Avatar
Default Re: (PINKS)
I probably will, but Im going to start off with a 55 shot 1st. Thanks for the replys guys. This is all exactly what I wanted to hear. Oh and is the ZEX filter worth buying?
Old Sep 13, 2006 | 09:59 PM
PINKS's Avatar
No
No zex filter
No zex plugs
I purchased a bottle heater and a nitrous pressure gauge when I had mine installed, just because nitrous was so expensive back in the day and getting the bottle pressure perfect just made it that much more fun
Old Sep 13, 2006 | 10:02 PM
carlosd68's Avatar
i had the same set up as you....i used a 55 shot ..retard my timing,,,,and in less than a month i messed up my piston rings.....now my zex dry kit is up for sale
Old Sep 14, 2006 | 07:17 AM
DC5ftmfw's Avatar
Default Re: (carlosd68)
carlos: where did you put your nozzle at? Was it right at the throttle body or was it about 6-12"s away? and did you use colder plugs? How long did you spray for each time you used it?
Old Sep 14, 2006 | 09:54 AM
carlosd68's Avatar
IT WAS ABOUT 7 INCHES AWAY FROM THE THROTTLE BODY... I USED NGK COLDER SPARK PLUGS I THINK 2 DEGREES COLDER......
Old Sep 14, 2006 | 10:17 AM
DC5ftmfw's Avatar
Hmm...did you check your a/f ratio? How healthy was your motor before you sprayed it...? It could've been that the rings were already going bad and then extra pressure from the n20 finished them off. I don't have a clue, just guessing. I rarely hear of something like that from a 50-55 shot.
Old Sep 15, 2006 | 03:34 PM
carlosd68's Avatar
my motor was in very good condition before spraying only had 70,000 miles.... i wouldnt recommend nitrous but if u spray good luck and let me know how it goes...dont get me wrong ur going to LOVE the 55 shot it pulls hard! it made a whole second difference for me at the 1/8 of a mile...
EfSedanLove
Jun 3, 2008 04:37 AM
JDMDC4life
Oct 12, 2006 02:18 PM
DC5ftmfw
Sep 4, 2006 06:45 PM
TeamDOHCside
Dec 24, 2003 08:26 AM
BEEFEDUPACCORD
Jan 30, 2002 11:39 AM
