NEW BRAKES
Old Sep 10, 2006 | 05:56 PM
hondajav06's Avatar
Default NEW BRAKES
I want to change my brake pads myself but dont know how i have an 93 EG hatch
i need to know what tools do i need and a procedure i looked around in this fourm but got no result please help any info will be gratley be appreciate it.
Old Sep 10, 2006 | 05:57 PM
JDM-EJ1's Avatar
Default Re: NEW BRAKES (hondajav06)
I would start by getting a Haynes manual.
Old Sep 10, 2006 | 06:03 PM
hondajav06's Avatar
Default Re: NEW BRAKES (JDM-EJ1)
!!!ANY ONE ELSE!!!!
-THANKS ANYWAY-
Old Sep 10, 2006 | 06:05 PM
Stingray96's Avatar
Jack it up, Take the wheels off.
There is a bolt that goes on the bottom of the caliper, loosen it and take it out. The caliper should flip up.
Take old ones out, put new ones in.
Re-assemble.
Old Sep 10, 2006 | 06:28 PM
EG2Driver's Avatar
Default Re: (Stingray96)
if you want to i'll take pix of what needs to be done, but i can only do so tomorrow. Let me know
Old Sep 10, 2006 | 06:37 PM
ObedD15's Avatar
Its really simple to do. pull wheel, a (1) bolt, rotate caliper out of the way, remove pads and shims, put shims on new pads (put some of the brake lube between the shims and pad to reduce squeal), you may have to open your bleed valve to get the piston back in, rotate caliper back, install bolt and bleed your brakes, be sure to check you reservoir when done. Good luck.
I have a question why is it always a noob who refuses to get a repair manual? I would rather read how to do a task then ask on a forum.
Old Sep 10, 2006 | 06:39 PM
hondajav06's Avatar
Default Re: (DeadEnd9009)
kinda know now but what if you dont have the lock nut wrench what else can i use to push in the piston boot in, the rest i kind of got down packed
Old Sep 10, 2006 | 06:41 PM
Dodger2940's Avatar
Default Re: (hondajav06)
I use a C clamp to push the pistons back.
Old Sep 10, 2006 | 06:44 PM
hondajav06's Avatar
Default Re: (Dodger2940)
THANKS FOR ALL THE HELP GOT THEM IN RUNNING FINE
Old Sep 10, 2006 | 06:45 PM
hondajav06's Avatar
Old Sep 10, 2006 | 06:47 PM
civic nation's Avatar
i sometimes use big channel locks
Old Sep 10, 2006 | 07:49 PM
DelSolMarine's Avatar
Default Re: (civic nation)
get a c clamp to push piston back in on ur eg brakes makes it easier... its pretty common sense to change them
Old Sep 10, 2006 | 07:50 PM
EL Vap133's Avatar
Get a rachet and a 12mm socket.
Old Sep 11, 2006 | 12:36 PM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondajav06 &raquo;</TD></TR><TR><TD CLASS="quote">THANKS FOR ALL THE HELP GOT THEM IN RUNNING FINE</TD></TR></TABLE>
let this thread die away
spens 91 Ef
10
Aug 11, 2009 01:58 PM
Nocturnal
Jan 4, 2003 05:25 AM
2000gsrsedan
Dec 4, 2002 11:56 AM
damarksman
Aug 23, 2002 10:46 AM
LOwrestling2001
Jul 26, 2002 02:46 PM
