b16 turbo
Old Sep 9, 2006 | 10:55 PM
HB1234's Avatar
Default b16 turbo
Modified by HB1234 at 10:57 PM 8/18/2007
Old Sep 10, 2006 | 01:40 PM
SubTitle's Avatar
Default Re: b16 turbo (HB1234)
with a good tuner ,you should achieve the 300whp mark you're looking for, maybe a little bit more.
Old Sep 10, 2006 | 02:21 PM
Jason703Racing's Avatar
Default Re: b16 turbo (SubTitle)
300WHP is the max you would wanna take the b16. thats going to its limit on the internals.. With a good tuner its very possible. Im doing a setup right now and looking for 280-300whp as well on my b16 when im done putting it together, but im goin with a bigger turbo becuase i do plan on building the motor. I will be posting pics of the setup as it comes along very shortly
Old Sep 10, 2006 | 02:28 PM
NJIN BUILDR's Avatar
Personally for your goal I would just use a stock intake and tb.Either 550 or 750 injectors would be fine.I would get the 750's as they are just a few bucks more and give you a little more room for power.Start right out with a forged piston.The stock rods are ok,but at this point a set of Eagles would also be a good idea.Save the money on the aftermarket flywheel,the stocker is fine.It's pretty easy to hit 300hp with a b16.A 38mm wastegate will be fine.
Old Sep 10, 2006 | 02:52 PM
Default Re: b16 turbo (NJIN BUILDR)
id say go with RC 740cc injectors as thats the biggest you can go WITH OUT a resistor box But i agree dont waste your money on a intake manifold or flywheel you can make that goal with out those parts but just make sure you have a good clutch up to the job and a good tune
teknicalissue
Aug 21, 2010 01:54 PM
94delsol-b16a
Feb 10, 2009 09:09 PM
lukerc45
Nov 23, 2007 09:45 PM
American.Graffiti
Aug 4, 2006 12:33 PM
