Parts question
Old Sep 8, 2006 | 10:35 PM
SOHC4life 96's Avatar
Default Parts question
Here is the deal... I was doing some work on my car and when I was taking of one of the front wheels I noticed the entire hub was loose. I could move the tob and bottom of the wheel in towards the car. The problem is I don't really know what the part is called or what to look for. It's basically the piece that locks the hub into place. It's the piece that the axle sits on.
If anyone knows what the piece is called or if they could get me a part number for it, I would really appreciate it.
Old Sep 8, 2006 | 11:06 PM
Default Re: Parts question (JJDrivesAJazz)
I don't have one at the moment but should be able to get one.
Old Sep 8, 2006 | 11:18 PM
cwd14's Avatar
Default Re: Parts question (SOHC4life 96)
if you are talking about your rotor then who cares if you can move it since it is held in place by the tire when you screw the lugs on. but if it is the entire knuckle that you can move then that is a problem.
Old Sep 9, 2006 | 12:18 AM
Default Re: Parts question (cwd14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cwd14 &raquo;</TD></TR><TR><TD CLASS="quote">if you are talking about your rotor then who cares if you can move it since it is held in place by the tire when you screw the lugs on. but if it is the entire knuckle that you can move then that is a problem.</TD></TR></TABLE>
Yes it's the entire knuckle and yes it is a problem. And I need the part to fix it.
Old Sep 9, 2006 | 05:13 AM
CardDealer's Avatar
Banned
Modified by CardDealer at 9:10 AM 11/16/2006
Old Sep 9, 2006 | 06:56 AM
HondaJack's Avatar
Default Re: Parts question (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">That's a bad wheel bearing. You'd need to take the hub off and press the old one out and a new one in.</TD></TR></TABLE>
Yepp
Old Sep 9, 2006 | 08:10 AM
Default Re: Parts question (HondaJack)
No, I inspected the wheel bearing and it's fine.
I got a couple pictures of it.
Old Sep 9, 2006 | 09:34 AM
Bump... I'd like to get my car back on the road
Old Sep 9, 2006 | 09:50 AM
thehatchninja's Avatar
it could be a ball joint.
Old Sep 9, 2006 | 09:58 AM
ntrider's Avatar
Default Re: (thehatchninja)
hopefully this is the right diagram but is your part on here?
I wasn't sure on your car this diagram is from a 98 y8.
Old Sep 9, 2006 | 07:13 PM
Default Re: (ntrider)
See ntrider, I looked at the same diagram and I'm thinking it's the part in number 1 between the two rings... But I'm not sure.
Anyone know for sure?
Old Sep 10, 2006 | 03:11 AM
Default Re: (SOHC4life 96)
bump...
Old Sep 10, 2006 | 06:15 AM
CardDealer's Avatar
Banned
FYI: Part number 1 is a brake caliper boot rebuild kit.
Old Sep 10, 2006 | 10:02 AM
Default Re: (schlit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schlit &raquo;</TD></TR><TR><TD CLASS="quote">FYI: Part number 1 is a brake caliper boot rebuild kit.</TD></TR></TABLE>
Ahhhh, thank you. So I'm not even close.
Bump I really need to know what the part is.
Old Sep 10, 2006 | 11:41 AM
jdeemseerx's Avatar
replace the hub and wheel bearing and call it a day
Old Sep 10, 2006 | 04:36 PM
Default Re: (jdeemseerx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">replace the hub and wheel bearing and call it a day </TD></TR></TABLE>
I'm not going to buy a new hub, my hub is fine. The part I took out needs to be replaced.
Bump for an answer
Old Sep 10, 2006 | 05:03 PM
jdeemseerx's Avatar
is that is or is it not one of the races from the wheel bearing? usually when you ride on a bad wheel bearing for too long without noticing, you can f up the suface of the hub that the bearing gets pressed onto.. which is why i personally always change wheel bearings and hubs all at once.. but your also the one that said your wheel bearing is fine so if your that sure of yourself why are you on here for answers at all?
Old Sep 10, 2006 | 05:10 PM
90dteg's Avatar
bad wheel bearing will not mess up your hub unless you do some real damage.
NOTE: THE RACE IS OUT OF THE BEARING. THIS IS BAD!!!!! THE BEARINGS ARE SEALED AND ARE NOT SUSSPOED TO DO THAT.
You need a wheel bearing.
Old Sep 10, 2006 | 05:18 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: (90dteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90dteg &raquo;</TD></TR><TR><TD CLASS="quote">NOTE: THE RACE IS OUT OF THE BEARING. THIS IS BAD!!!!! THE BEARINGS ARE SEALED AND ARE NOT SUSPPOED TO DO THAT.
You need a wheel bearing.</TD></TR></TABLE>
Old Sep 10, 2006 | 06:21 PM
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx &raquo;</TD></TR><TR><TD CLASS="quote">is that is or is it not one of the races from the wheel bearing? usually when you ride on a bad wheel bearing for too long without noticing, you can f up the suface of the hub that the bearing gets pressed onto.. which is why i personally always change wheel bearings and hubs all at once.. but your also the one that said your wheel bearing is fine so if your that sure of yourself why are you on here for answers at all? </TD></TR></TABLE>
I guess it is the race from one of the wheel bearings. However I didn't know that, that's what I was asking.
So all I need to do is buy a new wheel bearing and get it pressed back in and I should be fine? (for the time being, I don't have $130 for a new hub right now)
Old Sep 11, 2006 | 06:06 AM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">
So all I need to do is buy a new wheel bearing and get it pressed back in and I should be fine? </TD></TR></TABLE>
Try that
SanJose408
Jul 26, 2008 10:23 PM
CardDealer
13
Dec 5, 2006 06:48 PM
K-Spec
Oct 21, 2006 08:41 AM
tigueremalo
17
May 17, 2006 08:41 PM
xlusiveracer
Mar 15, 2006 01:25 PM
